Old 07-28-2008, 10:55 PM   #11 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '010 Insight EX
90 day: 51.5 mpg (US)
I too own a V* Toyota, mine however is a 4-runner. I have found that the best inner city technique is quick acceleration to its ideal cruising speed which is 40mph. On the hwy, I don't think it wise to shift from neutral to drive @ speeds above 35mph, so for me pulse and glide is useless. The 4-runner responds best @ a hwy speed of 55mph, above that and I watch the meter plummit religiously.
Aero mods and psi are your friend with these beasts on the hwy. In fact I saw a 3mpg jump by folding in both mirrors on a long hwy run recently.
So good luck, 24mpg is quite respectable for a Tundra ...
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 07-30-2008, 05:05 PM   #12 (permalink)
freeway coasting
Originally Posted by ScottC33 View Post
So let's assume you're the only guy on the freeway, and you have the ability to coast safely from 60 mph all the way down to 20 mph (just as an example), then speed up slowly to 60 mph again (and repeat)? Would that produce the highest mpg, all other things being equal? Or is there some science behind the theory that you should coast only until you hit some predetermined mph before accelerating again?
Obviously, the more you coast (and slower you travel) in neutral, the more fuel you will use to speed up again. What are the current thoughts regarding how far/long you should IDEALLY coast before speeding up again?
I'm trying to figure you whether people coast until hitting 50-55 mph ONLY BECAUSE it's unsafe to go any slower on the freeway, or because there's some other fuel-efficiency issue involved.
This is not an EOC post. All coasting, for purposes of this question, will be done in neutral.
Thanks so much for your input.
Scott
The Chrysler team that used to win the Mobil Economy Run a bunch of times,never coasted,and tried to drive a constant throttle setting,allowing the car to accelerate on downhills,and lose speed on uphill stretches.Simply moving the throttle introduces inefficiency once up to speed.The Coast and Burn technique was introduced in the Shell Mileage Marathon in 1940,it was called "Momentum Driving",it was held on a closed course,not out on public roads.In the "unlimited class",where all the fabulous records were set,the cars were accelerated to 15-mph,engines were shut off,they coasted to 3-mph,and then were bump-started to repeat the process.By allowing your car to decelerate probably introduces the greatest waste you could make.Maintaining a constant speed should yield you the highest mpg.Otherwise,if there is no other traffic,slow down to 35-40 mph.This has been demonstrated to offer the best economy unless your willing to spend the rest of your life on one commute.
Experiment: coast down distances (rolling resistance) @ various tire pressures MetroMPG EcoModding Central 72 02-25-2012 09:09 PM
How do you perform a coast down test 88CRX Aerodynamics 19 01-18-2011 09:58 PM
Disengaging auto trans for coast. beatr911 EcoModding Central 18 06-24-2008 05:04 PM
Coast Button Phreakuency Instrumentation 1 06-13-2008 12:03 PM
Why should I coast with the motor off? DAN Hypermiling / EcoDriver's Ed 10 02-04-2008 02:44 PM
