Old 01-28-2012, 12:01 PM   #1 (permalink)
sendler's Avatar
Honda CBR250R FI Single - '011 CBR250R
90 day: 92.93 mpg (US)
Ninja 250R SE Green - '09 Ninja 250R SE
90 day: 65.9 mpg (US)
2001 Honda Insight stick - '01 Insight manual
90 day: 60.68 mpg (US)
2009 Honda Fit auto - '09 Fit Auto
90 day: 32.56 mpg (US)
Kawi Ninja650 - '07 Ninja650
90 day: 65.5 mpg (US)
How long until we get rid of the camshaft?
How long before we are finally able to get rid of the cam shaft and put the infinite possibilities of computer control into our valve timing with electro magnetic lift? With direct injection and stratified charge, we could then also tend to eliminate the throttle plate.
Old 01-28-2012, 01:43 PM   #2 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...I've wondered about that too, for years.
...if they ever migrate up from 12VDC electrical system to 48VDC as they proposed awhile ago, there's a darn good chance that direct electrical control of valve lift & duration could be 100% under computer control...unfortunately, it takes lots of CURRENT to make inertia "change" positions quickly, hence the need for higher VOLTAGE source.
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Last edited by Old Tele man; 01-28-2012 at 06:05 PM.. Reason: spelling error corrected
Old 01-28-2012, 02:02 PM   #3 (permalink)
You'll never get rid of the cam because it will always be cheaper, more efficient and more reliable than stuffing magnetic coils in a hot vibrating environment. Throttleless gasoline engines have been around for years.
Old 01-28-2012, 03:17 PM   #4 (permalink)
Ladogaboy - '011 Lancer EVO GSR
Team Emperor
90 day: 27.18 mpg (US)
E85 EVO - '011 Lancer EVO GSR
90 day: 21.38 mpg (US)
In terms of reliability, magnetic properties can be affected by the engine heat, so that is something else to take into consideration.
Old 01-28-2012, 04:56 PM   #5 (permalink)
Sendler, sadly it may well take a long long time.
OHC and 4 valve / cylinder were around at the turn of the last century (ie 1900's or so) and look how long they took to become more or less standard.
Will technology drive cars or will the demands of the car makers drive technology?
I personally think car makers will adapt when they have absolutely no other options...and even then it will be a tantrum session to get it all to happen.
Peter.
Old 01-28-2012, 06:24 PM   #6 (permalink)
JRMichler's Avatar
Nameless - '06 Canyon
90 day: 33.19 mpg (US)
I would not say never, but trying to pull a valve almost a half inch using an electromagnet is a real challenge. Doing it at the speeds necessary is beyond available materials.
I designed an electromagnet once to pull 1600 lbs over a quarter inch air gap. It needed over 200 volts at 50 amps to drive it.
34.9 MPG summer 2011. Winter 2011-2012 was warm, so only dropped to 30.1 MPG.
Old 01-28-2012, 06:37 PM   #7 (permalink)
Gen II Prianista
Rokeby's Avatar
I guess hydralics are out of the running... too slow/complicated?
Old 01-28-2012, 06:51 PM   #8 (permalink)
Team Emperor
I think the biggest problem is that no one wants to put the energy into such a radical change for what is, ultimately, a dying technology.
Old 01-28-2012, 07:03 PM   #9 (permalink)
As soon as it's cheaper to do it differently.
Old 01-28-2012, 07:06 PM   #10 (permalink)
JRMichler's Avatar
Electromagnets and hydraulics are much more complex and expensive than some bumps on a shaft. Also camshafts have much higher mechanical efficiency.
Dual cams with dual VVT have much of the theoretical efficiency benefits of fully programmable valve timing.
