Old 02-06-2008, 11:42 PM   #11 (permalink)
Send a message via AIM to Gone4
I have an automatic right now, that I currently don't drive; my little brother has it while I am at school. I only started to begin using some efficiency techniques before I went back to using my legs. Keeping the RPM low - although I need to find the optimal range somewhere for my 2001 Focus SE - often by accelerating at a moderate pace and letting up on the accelerator so the tranny will shift earlier. I experienced huge savings just by keeping a more constant RPM and not a constant speed over the white and green mountains. I tried EOC and my car didn't like it, to say the least... the nasty thud scared me.
Old 02-07-2008, 12:17 AM   #12 (permalink)
ECO-Evolution
Lazarus's Avatar
Iron Horse (retired) - '97 Iron horse Intrepid
Ninja - '08 Kawasaki 250R
90 day: 76.23 mpg (US)
Have an automatic. No EOC. Engine off at lights and pick the best route that will allow me to get into OD quickly and stay there as much as possible. Speed 55-60 on the highway and drive with load on the hills.
"Judge a person by their questions rather than their answers."
Old 02-07-2008, 02:54 AM   #13 (permalink)
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
Engine on Pees and Gees, are what really work for me. I also found out that there was little or no loss from going ~63mph instead of ~55mph... So Peeing and Geeing, WOT acceleration when I know I won't brake, staying of the brakes as much as possible in the city, and cruising at ~60+mph highway are surefire ways to pull 30+mpg with the six.
Old 02-07-2008, 03:09 AM   #14 (permalink)
MPG...what?
Terkle - '97 Toyota Tercel Whitehawk
90 day: 40.91 mpg (US)
Bubble - '10 Toyota Yaris base
90 day: 41.88 mpg (US)
Deva - '13 Chevrolet Spark LS
90 day: 39.82 mpg (US)
Malibu5 - '82 Chevrolet Malibu Classic
90 day: 17.61 mpg (US)
Highlander - '06 Toyota Highlander Limited
Send a message via AIM to malibuguy
what i've been doing in the cavy, is neutral costing down hills, shutting off the engine at a fresh red light & accelerating as moderate as possible...i count off 1...2...3 etc for each 4-5mph i gain, torque converter lock-up doesn't happen until around 38mph, i try to do most of my "harder accelerating" then
-Greg...the exhaust freak.
-06 Highlander 3.3awd
-10 Yaris sedan
-97 Tercel, 1NZfe swapped
-96 Tercel
-82 Malibu 1UZfe swapped
-19 Fit (wifey ride)
www.pipedreamsfab.com
Old 02-07-2008, 08:46 AM   #15 (permalink)
The Civic - '00 Honda Civic DX
90 day: 37.05 mpg (US)
  • Automatic 2000 Civic DX (4-speed with lock at 40mph in 4th), no plans to swap it
  • I'm P&Ging, looking way ahead for coasting opportunities.
  • No EOC temptations yet.
  • Looking into 'stealth' aero mods since I spend so much time at 70mph
  • I'm curious about neutral down hills instead of in gear, I'm not sure what the Honda TCU's Grade-Logic might already be doing. Both ways reads 9,999 mpg on the ScanGauge. I definitely feel engine braking when in gear...but don't the wheels pump the engine when coasting in gear (injectors off), while in neutral the injectors are on light-duty? I've also read that shifting too often into neutral and drive could be bad for the trans.
  • I dont have enough data yet to conclude what my improvements are, but there are some definite improvements
Old 02-07-2008, 10:15 AM   #16 (permalink)
Who
UnderModded
Pablo - '07 Hyundai Santa Fe AWD
90 day: 23.62 mpg (US)
Originally Posted by DifferentPointofView View Post
If you find that it down shifts all the time going up a hill, the best way is to GAIN speed just before you go up the hill, and maintain that throttle until you get to the top, then neutral coast down, or EOC down the hill.
I'm not sure that I'd agree that's the best way. I'll agree with gaining speed before you hit the hill, but I'd go into the hill with a set engine load in mind that will having you hitting the summit at a slower speed. The less traffic the lower that summit speed can be. If you let you speed bleed going over the hills and then recoup it as the road dips down you keep your power curve far far flatter and I would think that would be more optimal.
From a LOD perspective, where my regular flat stuff is all in the 30s, ideally lower 30s, moderate hills try and restrict LOD to 50, bigger 60, major 70. Grade and length of hill both have to be factored in, along with how much of an obstruction you might be.
For my slushbox strategy, I:
  • restrict EOCs to under 1000' where I'm coming to a top if tranny's warm
  • frequently shift to neutral whenever a coast opportunity is there
  • sometimes use the manual shifter option to force upshifts sooner
  • if not manually upshifting I lift off at 62 to force 5th gear upshift
  • try to get into 5th quick and stay there, 62kph to shift in, 50 shifts down
  • accelerate at 50 LOD in lower gears, with grade opportunites in 5th
  • switch off for lights over 20 seconds
  • downshift for mild DFCO when traffic slows up
  • rarely let SWMBO drive, although it's hers, she drives my stick Accord!
The biggest thing for me is getting into 5th efficiently, my sweet spot is from 60 to 90 kph, if I can't get into 5th in urban areas (where I drive most of teh time), I P&G because 4th is at least 15% worse for FE.
Old 02-07-2008, 10:28 AM   #17 (permalink)
RE: Neutral vs In-Gear
OK, I did some careful observation of the GPH (gallons per hour) on my ScanGauge II this morning during the commute. As far as the civic is concerned, this is the data I've got:
DOWNHILL COASTING:
In-Gear : 0.00GPH, but with slight engine braking
Neutral : 0.22GPH, with better speed retention
COMPLETELY STOPPED:
In-Gear : 0.20GPH
Neutral : 0.22GPH
So I'm happy enough knowing that I'm only using .02GPH more by keeping it in gear while waiting at a light vs Neutral... however I'm still on the fence about which is better for downhill coasting... for the sake of transmission wear, I'd be inclined to coast in-gear for most of the time.
Old 02-07-2008, 10:29 PM   #18 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
Improvements
I know for sure I need to get a full rad-block and seal the hood. I have the largest gap sealed on the leading edge, but cold air seeps in as it always does.
I did some observing over the last couple days too...
50 MPH is all I can get from 2000 RPM in full lockup. My most efficient speeds are in the 45-55 range if the momentum is carried.
On the highway, I use DPOV's speed building technique on downhills to load-up the next hill and scrub-off speed. Maybe I need to look at LOD?
The current cruising target is 55-60 MPH instead of the old 71-76 (depending on limit and traffic patterns). 60 is about the fastest before that wall of air hits and the begins turning too quickly (2 strikes). I think the 'Teg suffers from "sporty" gearing and fuel maps.
Not sure if this works best for acceleration but the car won't shift under 2-grand unless the low-loads are detected. So, to get anywhere, I give it about 40-50% TPS, lift at 2300-2500, shifts, etc. If traffic is in the way, lift at 2xxx RPM and then throttle.
Getting on the highway, I use 3K as the rule and lift. The cable mod overcomes the upshift uphill with a quick lift of the right foot, and then the throttle plate opens. The game ensues of how much pedal to give it before it wants to kick down. Apparently it's different with a passenger (LOD factor) -- it'll downshift briskly. Getting up to 55-60 is tough overall.
Reduced pumping losses with top gear and high TPS is the theory.
I'm curious about this method -- I used to try it, but the Weather changed too much to test it properly. With WOT the open-loop kicks-in, so is it closer to 90%? I wonder if the FE at WOT or TPS-90 to 60 MPH in 2nd gear onward is lower than what I'm trying, or if slower is better.
In town, I'm constantly popping into Neutral and back in D or D3 (D3 reduced the Grade-Logic madness) -- maximizing coast.
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Old 02-07-2008, 10:50 PM   #19 (permalink)
Bicycle Junky
NoCO2's Avatar
Putsaround - '96 Toyota Camry LE
The Commuter - '07 Trek 1000SL
90 day: 617.28 mpg (US)
Zippy - '91 Honda Civic DX
90 day: 33.29 mpg (US)
Wow, if you're pulling 30mpg with a V6 doing that, that's basically what I do with my Camry (I p&g with engine on, shifting into neutral), I can't wait to see what my fuel millage average is when I finish this tank off, the sad thing is is that I don't think it's going to be gone before spring break which means I am going to have to fill it before it's fully empty so the trip odometer won't read a nice pretty 450-500 miles on a single tank...god that would be lovely.
Righ now I'm at 130 miles to this tank and haven't even touched the 3/4 tank line
Why the Civic VX is a superior highway fuel economy (FE) machine MetroMPG General Efficiency Discussion 9 10-10-2010 05:26 AM
Better injectors for better FE tasdrouille EcoModding Central 6 01-31-2008 05:29 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
