Go Back   EcoModder Forum > AltModding > Saving@Home
Old 01-09-2018, 04:01 PM   #11 (permalink)
Google "secondary burn wood stoves"
and
"Adding secondary burn tubes to your wood stove"
The Following 2 Users Say Thank You to redneck For This Useful Post:
Daox (01-09-2018), gearheadeh (01-10-2018)
Old 01-09-2018, 05:08 PM   #12 (permalink)
Ecomuggler
90 day: 40.43 mpg (US)
90 day: 33.55 mpg (US)
An afterburner?
Old 01-10-2018, 09:05 AM   #13 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
Yep.
Transmission type Efficiency
Old 01-11-2018, 02:18 AM   #14 (permalink)
tinkerer
I neglected to mention I cant do no permanent mods to the stove it self. I have added 2 stainless 3/8 fuel lines they run from the intake to the inside edge of the outlet fitting. It did raise stack temps about 150f to about 550 before it reaches the horizontal section that has been increased from 12" to 32. I have a blower running up 4 inch pipe across the horizontal section and thru a piece of dryer duct on top. I also added a 3" computer fan blowing around the inner housing .025 amp but seams to push the heat more into the room. When I get back to work and am not in such a pinch money wise plan on making a over size heat exchanger with a car catalyst mounted under it. Also a wedge shape deflector to set on the top to push head out more using the natural convection, but keep the ideas coming!
Old 01-12-2018, 10:31 PM   #15 (permalink)
tinkerer
Shameful using motor oil to get fire going. Kids let fire die while I was out putting in job applications.
Old 01-13-2018, 02:11 PM   #16 (permalink)
wdb
lurker's apprentice
PlainJane - '12 Toyota Tacoma Base 4WD Access Cab
90 day: 20.98 mpg (US)
Secondary burn is pretty common in newer stove designs. We just got a new Jotul that has it.
Those stovepipe add-ons create a LOT more maintenance, increase creosote buildup and concentrations of same, raise the risk of chimney fire, yada yada. Yep that's right I'm not a fan. I've seen them on oil burner stacks and that's a different kettle of fish. Getting more heat out of the exhaust is best done with masonry and/or a nice long run of stovepipe inside the heated area IMO.
We looked into cold air intakes. Our stove experts recommended against them. New stoves don't really draw much air. They only recommend them if the house is really, really tightly sealed, which ours is definitely not.
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
