How much do grill openings effect Cd?
I have heard that between 1/4 and 1/3 of the aerodynamic drag on a car is from the cooling openings. That sounds like a LOT of the drag on a car is from air going through the radiator, and I have a hard time believing that cooling causes 1/4 to 1/3 of the aerodynamic drag on a car. If that were the case, wouldn't I have lost a measurable amount of gas mileage when the front grill fell off my 2005 Civic? I was sure that having a big hole in the front of my car would hurt highway mileage at least a little, but the effect on gas mileage even at 60-70 MPH on the highway was not measurable. Also, if drag from cooling was so significant, why do people only get 1-3 percent MPG improvements, presumably mostly from faster warm up, from a full grill block? nPlease help me understand!
Enough to where electric vehicles have closed off grill openings.
If you block off the grill you may have the electric fans kinking on more, eating up some of the savings. Newer vehicles must have spent time in the wind tunnel working on minimizing the grill opening effects compared to vehicles from years ago. That's the only thing I can think of. |
That's a ridiculous % of drag. Where did you hear that?
Aerodynamic Investigation of Vehicle Cooling-Drag ...It is estimated that about 10% of the overall aerodynamic drag originates from the cooling...
https://www.slideshare.net/mobile/fr...g-aerodynamics ...cooling and ventilation system ~ 10%... 3% or 1/3 of the 10% seems reasonable for a DIY modification to a still functioning cooling system |
They do prefer being warmer than 80 * f. |
