How much do grill openings effect Cd?
I have heard that between 1/4 and 1/3 of the aerodynamic drag on a car is from the cooling openings. That sounds like a LOT of the drag on a car is from air going through the radiator, and I have a hard time believing that cooling causes 1/4 to 1/3 of the aerodynamic drag on a car. If that were the case, wouldn't I have lost a measurable amount of gas mileage when the front grill fell off my 2005 Civic? I was sure that having a big hole in the front of my car would hurt highway mileage at least a little, but the effect on gas mileage even at 60-70 MPH on the highway was not measurable. Also, if drag from cooling was so significant, why do people only get 1-3 percent MPG improvements, presumably mostly from faster warm up, from a full grill block? nPlease help me understand!
Enough to where electric vehicles have closed off grill openings.
If you block off the grill you may have the electric fans kinking on more, eating up some of the savings. Newer vehicles must have spent time in the wind tunnel working on minimizing the grill opening effects compared to vehicles from years ago. That's the only thing I can think of. |
That's a ridiculous % of drag. Where did you hear that?
Aerodynamic Investigation of Vehicle Cooling-Drag ...It is estimated that about 10% of the overall aerodynamic drag originates from the cooling...
https://www.slideshare.net/mobile/fr...g-aerodynamics ...cooling and ventilation system ~ 10%... 3% or 1/3 of the 10% seems reasonable for a DIY modification to a still functioning cooling system |
They do prefer being warmer than 80 * f. |
Ok, so I duct taped over the upper grill on my 2005 Civic but left the bottom open since that is where I put my transmission oil cooling radiator, and I don't want to overheat my transmission. I will reply with an update soon.
Also, while many newer cars have huge grills, much of that is fake. People want to believe they have a mouth-breathing monster, but there is no reason for it.
how much
2% is credited to good racing design. 1976 Ford Lameller Grille was associated with a 12% drag reduction 1938 Adler-Jaray saw 15.78% with a 100% block 2013 Dodge Dart,active shutters 3-to-5% 1982 Pontiac Trans AM bottom-breather 3.08% 1967 Corvette EV with 100% block 6.5% 1986 FIAT R&D 100% block 10.2% 1978 Chevette 4-DR with 100% block 7.56% 2009 Audi A2 100% block 9.7% 2007 Ford Fusion 999 hybrid LSR 100% block 7.35% By the old metric,you'd see a 1% improvement in HWY mpg for every 2% drag reduction,based only upon the original mpg. |
