Old 09-23-2017, 07:29 PM   #11 (permalink)
The wind will rip it off at the first opportunity.
High speed air is as unforgiving as a curb. Observe the struts and turnbuckles on a time attack car just to get a little adjustment.
A backward leaning air dam will increase underbody air pressure. A forward leaning air dam will decrease underbody air pressure. The extreme is the diverter on the bottom of the air dam on those time attack cars.
If the concern is ground strikes, why not a passive, hinged air dam with a roller on the bottom?
http://www.carscoops.com/2016/01/its-been-70-years-since-first-vw-beetle.html
Like this on a Cal Looker instead of the KdF-Wagen.
Old 09-24-2017, 07:01 AM   #12 (permalink)
teoman's Avatar
A3 - '12 Audi A3
If you have an airdam that is big then yes the wind would rip it apart. But something that is not so huge should be able to stay onboard.
Passive with rollers is a good idea but would the wind not push it back? How about passive with springs, the wind would push it open.
Is it even worth doing anything to this car?
https://goo.gl/images/DfCjbY
It seems fairly optimised already down there.
At 1:30 you get a view of the underside.
http://youtu.be/nTwkBXN6gtA
Old 09-24-2017, 11:21 AM   #13 (permalink)
CruzeMTgrind
BlueBawls - '14 Chevrolet Cruze Eco
90 day: 48.47 mpg (US)
Eddie - '02 Ford Explorer Eddie Bauer
90 day: 23.07 mpg (US)
I have been looking at doing something for my explorer. From what I have seen SUVS tend to get a larger boost. That would be why most new ones are sporting factory air dams. Yet it's interesting when u look at the rear of many they still leave pockets that will catch a ton of air in the bumper. Little parachute action in the 2000s will have to check a bit closer on some of the newer models. Wife's 2016 expedition has some parachute going on but nothing drastic like the 02 ex. I feel with most cars they have a slight rake to them now and nothing significant hanging down. Golf ball dimple laminar floor deal would be probably the best way to go for a belly pan obviously. Lot of work though from what others have posted. Otherwise wheel spats seem to be a great one. Since adding a dam decreases your ground clearance. You may have to suck it up and spend time on the pan if u drive in rougher areas. My local area would be terrible for a dam on any car. Transition into parking lots for the most part is only suits for an SUV. My Monte Carlo bottomed out like crazy as does my cruze that replaced it.
Old 09-25-2017, 08:41 AM   #14 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
I had 10" under my air dam corners and 12" in the canter covering all the junk hanging down under the nose. 30" forward of the contact point of the tire. It would still hit the "bad" driveways, cleared sidewalks and parking blocks (tryed 8"and 9" both hit too small of an aproch angle)
This was just before Darco.
Results from Darco
+.02Cd .(more drag)
"I have not seen an air dam that had a positive result."
Layne Christensen
Darko Technologies
And this is the man who runs the Ogden wind tunnel were many Bonneville salt flat racers test.
Conclusion
The air dam is a pice of a package. Without the belly pan it has trouble beeing positive.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following 5 Users Say Thank You to gumby79 For This Useful Post:
aerohead (09-30-2017), BamZipPow (09-25-2017), COcyclist (09-25-2017), freebeard (09-25-2017), mcrews (09-26-2017)
Old 09-25-2017, 11:02 AM   #15 (permalink)
CruzeMTgrind
Not sure how to take that but it's strictly dependent on the vehicle and the application of the mod. I understand the point of all piece of a package but people have been posting positive results with theirs on here. Don't see how that can all be summed up to driving more attentive. Need to have someone's aba testing linked in here.
Old 09-25-2017, 05:56 PM   #16 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 53.2 mpg (US)
Like this? http://ecomodder.com/forum/showthrea...9-a-27167.html
Or. http://ecomodder.com/forum/showthrea...-b-9732-3.html
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
The Following 3 Users Say Thank You to COcyclist For This Useful Post:
aerohead (09-30-2017), ecocruze (09-25-2017), mpg_numbers_guy (02-22-2018)
Old 09-25-2017, 05:58 PM   #17 (permalink)
CruzeMTgrind
Thank you!!!
Old 09-26-2017, 02:26 AM   #18 (permalink)
CruzeMTgrind
Don't forget the 98' Odessy 15% increase in highway economy.
Old 09-26-2017, 02:50 AM   #19 (permalink)
JockoT's Avatar
All That Jazz - '06 Honda Jazz i-DSI S
90 day: 48.72 mpg (US)
People Think They Are Thinking When They Are Merely Rearranging Their Prejudices
Old 09-26-2017, 07:29 AM   #20 (permalink)
beastie - '89 toyota hilux dolphin motorhome
Puggie - '98 Peugeot 406 Lx
Hi have not done aba testing on my air dam but stablitiy in cross winds is remarkably improved. Have not noticed a drop in mpg maybe a slight gain. Bottom of car is quite flat from factory. Think i will gain more by reducing parachute effect on rear bumper. Averaging 40 imperimal mpg on a 2.0 auto pugeot 406 estate. Car weighs about 1800kg. Full 70 litre tank might increase it abit. Gearing is almost diesel like. Top gear pulling 2100 revs at 60mph. Very high for a heavy 2.0 auto. Pugeout factory figures are nax 37mpg at 55mph. So must of gained something.
