Go Back   EcoModder Forum > AltModding > Saving@Home
View Poll Results: electrical useage in KWHs per month.
less then 50kwh 2 4.76%
50-100kwh 2 4.76%
100-200kwh 4 9.52%
200-300kwh 5 11.90%
300-500kwh 11 26.19%
500-1000kwh 9 21.43%
over 1000kwh per month 7 16.67%
No idea, just blindly pay the bill. 2 4.76%
Voters: 42. You may not vote on this poll
Old 08-16-2009, 02:30 PM   #31 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
90 day: 42.23 mpg (US)
Hello -
We have gas for heat and water, so that's not part of this :
If you "convert" the gas to kWh, I'm sure it puts us in the 300-500 zone, so that's what I voted. There's definitely room for improvement.
Just two of us and two kitties in a 900+ sqft home. We don't use much electricity, but the cats play Wii constantly, .
CarloSW2
American Solar Energy Society
Old 08-16-2009, 05:14 PM   #32 (permalink)
pickup - '01 Dakota Quad Cab 4x4 Sport
90 day: 16.35 mpg (US)
WOW, that would power my house a whole year!!! Not exaggerating!!!
I think I may have the solution to your problem! Make her pay the bill.
Good one Frank
She has no income.
I do have to say that she is good about doing laundry and using the oven during off peak hours.
High cooling costs are just a fact of life here, especially if someone is home all day. Some of my friend's/coworker's monthly usage would really make you head spin.
Old 08-16-2009, 05:23 PM   #33 (permalink)
Originally Posted by Snax View Post
[snip] The SOLUTION to this problem is the slightly more expensive version of motion sensing switch, where one must push a momentary button upon entering the room regardless - with no option to just leave it on, the timer starts and continues to reset until no more motion is sensed. They simply will not turn on without the button press however. Most of these types of switches are also compatible with CFLs as well, whereas the other version is not and will burn out both the switch and the CFL in short order.
The motion sensor switch in the garage might not be a good idea since the switch may not sense your body heat or motion from distances involved. Ever been sitting on the can in a public rest room and had the lights go out? In a garage (mine anyway) this could be dangerous. The timer switch would be the way to go IMO.
Last edited by taredog; 09-10-2009 at 11:33 PM.. Reason: corrected stupid "misteaks"
Old 08-17-2009, 01:57 AM   #34 (permalink)
Good point. I never really had an issue with turning off at a bad time when I did have one in the garage, except when the temperature was 98F, but I also have a couple of 4' florescent fixtures that are plugged into unswitched power with pull strings that get turned on if I am doing any real work out there.
Old 09-10-2009, 11:50 PM   #35 (permalink)
FWIW and for Frank to marvel at, my usage for 23 Jun-25 Jul was 1385kWh.
The Mechanism Behind Flow Separation LostCause Aerodynamics 46 07-15-2010 08:38 AM
Geothermal energy? DifferentPointofView Saving@Home 46 02-05-2009 11:15 PM
Presidential Candidate Views On Auto Energy Conservation Matt Herring The Lounge 2 09-06-2008 01:48 AM
Energy Program in Texas Lazarus Saving@Home 5 08-08-2008 01:24 AM
Monitoring tools cut home energy usage SVOboy Saving@Home 5 01-11-2008 01:00 AM
