Old 12-03-2009, 01:39 PM   #11 (permalink)
Maroon Ballon - '98 Town & Country LXI
90 day: 26.42 mpg (US)
MaEsTRO - '95 Metro 5spd hatch, 3 cyl
Google Phil Knox. I think he achieved some success.
Old 12-03-2009, 04:05 PM   #12 (permalink)
The Truck - '06 Silverado Ext Cab 4x4
Thanks for the input metrompg - I'm hoping to follow the general shape of Bondo's since his truck is more similar to mine that Phil's. After reading through his comments, I noticed that his first try was too steep and didn't really help his economy - I'm trying to avoid this.
thatguitarguy - thanks for your comments. As I mentioned in the first post, I've read everything I could find on this site regarding aero bed caps, including much information from Phil and others referring to him. I asked the questions to get clarity around a couple of concerns I had before building this and to get pointers and encouragement from the members of the board.
Old 12-05-2009, 05:11 PM   #13 (permalink)
template
check out the "aerodynamic streamlining template".It's created so you don't have to guess about anything.Kind of a go-no-go.
You CAN make the curvature MORE gentle although there will be some penalty to drag.
Also,if you sweep the sides in gently,you can gain even more.Mine is good for 13% mpg interstate.
Old 12-05-2009, 05:22 PM   #14 (permalink)
Rather than waste energy trying to curve the whole thing, IMO the better idea would be to radius the transition from roof to cover, then go straight to the tailgate.
Old 12-05-2009, 05:56 PM   #15 (permalink)
waste
I don't have a problem with that as the original shell was done that way.
As long as the "transition" curvature is there,the rest is a walk in the park,just like Kamm and the others claimed.
Curves are stronger,so the shell can be the lightest,although execution in man-hours could be measured geometrically.
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/how-much-radius-keep-flow-attached-aero-bed-11272.html
Posted By For Type Date
Kamm Back - Overview : Kosmix This thread Refback 03-29-2010 12:17 PM
Wiper cover test groar Aerodynamics 20 01-10-2012 05:37 PM
Yet Another Pickup Bed Cover Idea Big Dave Aerodynamics 4 05-17-2011 02:47 PM
Truck Aero, Bed cover DIY tonneau? Chris D. Aerodynamics 84 11-05-2010 12:56 AM
The Mechanism Behind Flow Separation LostCause Aerodynamics 46 07-15-2010 08:38 AM
Truck Bed Cover Ideas wyatt Aerodynamics 11 03-05-2009 11:00 PM
