Old 12-04-2010, 10:05 AM   #21 (permalink)
eco....something or other
wood hauler - '91 F-250
90 day: 22.06 mpg (US)
3800 Sunfire - '02 Sunfire
If they are rated at 51 psi, they are probably goodyear fuelmax. We sell them at work and I believe the only difference is the pressure rating. We don't sell many.
1991 F-250:
4.9L, Mazda 5 speed, 3.55 10.25" rear.
Old 12-05-2010, 07:31 PM   #22 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '010 Cobalt XFE
Originally Posted by ik04 View Post
Overinflating tires is more dangerous than it is economical. The tiny reduction in rolling resistance is not worth the reduced safety margin caused by rock hard tires. Use the high end of the recommended pressure range marked on the tire and no more or risk a big reduction in braking and cornering traction. That's my .02
I do 90 deg corners at 35mph on my cobalt at 50psi, it seems like it corners better not worse.
Old 12-05-2010, 07:44 PM   #23 (permalink)
Aveo - '08 Aveo LS
I feel better about how my car drives when its 44psi.
Old 12-05-2010, 09:09 PM   #24 (permalink)
Lil Sulf - '94 Corolla
90 day: 47.62 mpg (US)
Tire burst is well over 100 PSI. It might be a problem if you have really, really low quality tires or if your tire is damaged. Don't worry if your tire is a few PSI over max sidewall. You are much more likely to have problems with underinflation than overinflation.
My tires are at 65 PSI, at the moment, or they were a month ago before it got cold.
And that's without a Scangauge o.O
Old 12-06-2010, 09:24 AM   #25 (permalink)
PaleMelanesian's Avatar
PaleCivic - '96 Civic DX Sedan
90 day: 74.33 mpg (US)
Good last point, Sulfuric. It's time to check your tire pressure! Even if they were a little high last month, they're likely underinflated now.
- - - - -Best 11-mile commute: 105 mpg
- - - - -Best tank: 88.5 mpg / 1133 miles
Lower Grill Block 2005 Honda Civic Arminius EcoModding Central 12 10-04-2011 12:31 AM
grill "shield" rather than block? lunarhighway Aerodynamics 70 12-17-2010 03:50 AM
Grill Block question? chipX Aerodynamics 31 03-11-2009 03:47 PM
96-00 Civic Upper Grill Block Impulse Aerodynamics 2 07-12-2008 03:09 PM
pressure sensors for testing grill blocks? pasadena_commut Aerodynamics 15 07-10-2008 11:34 PM
