Old 06-14-2010, 05:07 PM   #1 (permalink)
eco....something or other
wood hauler - '91 F-250
90 day: 22.06 mpg (US)
3800 Sunfire - '02 Sunfire
How much will a brush guard hurt FE?
I have a brush guard I want to install to keep deer out of my engine bay and headlights. How much FE can I expect to lose, if any?
1991 F-250:
4.9L, Mazda 5 speed, 3.55 10.25" rear.
Old 06-14-2010, 05:25 PM   #2 (permalink)
comptiger5000's Avatar
The Beast - '98 Grand Cherokee (ZJ) 5.9 Limited
90 day: 14.58 mpg (US)
While I'm not really sure, I would think that as long as it isn't wider than the current front end, the FE penalty would come mostly from the added weight.
Call me crazy, but I actually try for mpg with this Jeep:
Typical driving: Back in Rochester for school, driving is 60 - 70% city
Old 06-14-2010, 06:40 PM   #3 (permalink)
good to hear....It is pretty light but strong. I can easily pick it up and set it on the truck by myself.
1991 F-250:
Old 06-14-2010, 09:25 PM   #4 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Zombie Insight - '00 Insight MT
90 day: 62.82 mpg (US)
I bet it will have a pretty large impact. The top five streamlines in this image pass over the car pretty much unmolested. If you stick some large diameter tubing in their path, Cd will increase. I'd imagine that the impact would be smaller on streamlines that are going to pass through a radiator or under the car, though.
Cylinders have high drag. Ellipses have lower drag, and streamlined bodies have the lowest drag. But you're not really interested in fairing each of the tubes of your bully bar, relative to the wind as presented to each tube, right?
Old 06-15-2010, 12:20 AM   #5 (permalink)
been thinkin about it......but it won't stick up much if any.
1991 F-250:
Old 06-15-2010, 07:16 AM   #6 (permalink)
Recreation Engineer
KamperBob's Avatar
Black Stallion - '02 Tundra 4WD xCab
Half Pint - '06 XT225
Originally Posted by RobertSmalls View Post
I wonder about center line only wind tunnel pix. It's just a 2D slice of a 3D problem. The one center is not at all representative of what happens at both sides.
As for the OP question, the brush guard may do very little damage. The rest of the vehicle has a lot to do with cleaning up the wake. I would worry about nose shape last.
My 2c
KB
Old 06-15-2010, 12:26 PM   #7 (permalink)
That's kinda the rule I have been using.....back-to-front. I figure if it does hurt a little FE then it is ok because a deer in my engine bay would be $$$$ to fix. This brush guard is my own insurance policy.
1991 F-250:
Old 06-15-2010, 01:30 PM   #8 (permalink)
Eco Dreamer
Versa - '08 Versa SL Hatchback
Those brushguards don't do squat for deer. The general consensus that I have heard many times is that they actually make the damage worse.
The Following User Says Thank You to stevet47 For This Useful Post:
Frank Lee (06-15-2010)
Old 06-15-2010, 02:19 PM   #9 (permalink)
Left Lane Ecodriver
I don't mean to belabor the point, but since I straightened out my twice-crashed front end last week, lean burn has been so much easier, and my FE has been 5-10mpg better. If you are okay with okay aero, then by all means, install it.
...fairing each of the tubes of your bully bar, relative to the wind as presented to each tube...
There's a much easier way. Basjoos' fully enclosed custom deer deflector, which doubles as a grille block:
http://aerocivic.com/imgs/front-3-4-z.jpg
It would also give you the opportunity to get those awful square corners off the front of your truck.
Old 06-15-2010, 02:51 PM   #10 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Similar to what guys racing the old Porsches discovered: impact damage was usually easier to repair when they'd removed the bumpers, as the damage tended to stay more localized instead of being spread throughout a larger area of the chassis.
Well, you already have it. If you've been keeping a good gas log perhaps it will reveal a difference... and perhaps not.
Longtime Lurker Looking for Miles ZX40 Electric Micro van mods & information rmay635703 Fossil Fuel Free 46 03-15-2012 07:21 PM
Driving the Scanguage for FE Harry6 Hypermiling / EcoDriver's Ed 12 04-02-2010 12:51 PM
Correlation between predicted and real-world fe? Frank Lee EcoModding Central 14 02-26-2010 02:54 PM
FE Acceleration thought experiment. TestDrive Hypermiling / EcoDriver's Ed 2 01-28-2009 10:24 AM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
