Go Back   EcoModder Forum > AltModding > Alternative Transportation
Old 11-28-2007, 08:49 PM   #1 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
How my home-built bicycle trailer lowers my MPG
(Originally written Nov. 06)
Just posted a new page at metrompg about...
How the cargo trailer I made for my beater 10-speed bike is hurting my MPG:
(130+ lbs: moving two Metro/Firefly transmissions by bicycle.)
Of course, total fuel used is the most important consideration, but since I typically get better mileage in sub/urban driving than I do on the highway, every time I use the bicycle for a local trip, my proportion of highway mileage for a given tank increases, so my overall mileage drops.
Other than for avoiding crappy weather, the main reason I use the car for local trips used to be to transport something too heavy/awkward for the beater 10-speed to handle.
But with the cargo trailer, I don't need the car for that any more.
So the MPG suffers. (I was going to calculate a figure, but, nah...)
On the plus side, kids seem to love seeing me hauling stuff behind the bike. It's kind of fun hearing them shout "cool! Where did you get THAT?" when I go by.
http://www.metrompg.com/posts/bike-trailer.htm
Old 11-28-2007, 08:50 PM   #2 (permalink)
People always ask how it's connected to the bike...
Same thing as my brother's kiddie trailer - a stout spring, the ends held in steel tube. If you click into the article on metrompg.com, there's a zoom in pic that shows the hinge close up.
There are also some ball-joint type hinges you can make out of (apparently) common inexpensive hardware store parts. See this site for examples:
Community Bike Cart Design - A simple, homemade, low-cost bike cart for car independence and community
EDIT:
the cost of my trailer was an afternoon & about $23. Plus I got exactly the size & shape I wanted.
Old 11-28-2007, 08:51 PM   #3 (permalink)
A safety note about construction...
If you're going to weld/braze zinc-coated EMT conduit for the frame, best to do it outside with a breeze (or fan)
The fumes of the heated zinc can cause "metal fever".
The thing has turned out to be remarkably useful. I never used to be worried about my beater bike getting stolen, but now that it has half the trailer hinge permanently attached to the rear axle, I sometimes worry about losing it.
Old 11-28-2007, 08:52 PM   #4 (permalink)
Just to clarify, yes, my MPG is actually worse now.
Because of the trailer, I use less fuel overall, true (and that's the important fact).
But by omitting some local driving (where I can achieve my highest MPG figures), my driving is further biased towards highway use. As a result of the higher proportion of (lower MPG) highway driving, my calculated MPG for a given tank is lower than it would have otherwise been had I just driven the car locally instead of using the bike/trailer.
Old 11-28-2007, 08:54 PM   #5 (permalink)
These are neat too.
2 downsides I can see, based on my limited experience:
- heavy loads will directly affect the bike's balance, since there's no torsional "give" at the hinge in the "roll" axis;
- related to that - if you lay the bike down, you could spill the trailer contents, since it has to lay down with the bike. So you'd either need a kick stand, or something to lean the bike against when you park
Small points, but there you go.
Old 12-14-2007, 12:53 PM   #6 (permalink)
Originally Posted by igo
I WILL be making one of these. I have some spare 26" wheels They might be tall but will do the job.
Cool! Check that bike cart design website. I think some of the designs use a larger wheel, but they offset the platform so it's not at axle height.
Old 12-14-2007, 01:36 PM   #7 (permalink)
Awesomeness personified
AndrewJ's Avatar
Harold - '94 Civic CX
90 day: 54.51 mpg (US)
Margot - '08 Big Dummy
Send a message via AIM to AndrewJ
Bikes at Work sells just their trailer hitch, but it's $50, and if you can weld you can probably make the same thing for about $12
Anyway they also have a cool bike-trailer calculator that shows you how much you can supposedly carry (in lbs.) on a bike trailer.
And there's even a pic of someone hauling 1000 lbs of cargo on three trailers with one bicycle. I think they used to have a video of the 1000lb haul, but I can't find it anymore.
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
Old 12-14-2007, 01:37 PM   #8 (permalink)
Awesome pic.
I'd think if you were doing 1000 lb hauls, you'd want to be pulling with a trike! Either that, or be a pro at trackstanding.
Old 12-14-2007, 01:43 PM   #9 (permalink)
AndrewJ's Avatar
forget trackstands, I think the key would be NEVER coming to a stop.
Old 11-14-2011, 10:57 AM   #10 (permalink)
aero guerrilla
Piwoslaw's Avatar
Svietlana - '05 307 SW
Diesel
90 day: 55.98 mpg (US)
Darin, if you tell me you had no part in this, I won't believe you!
Piwoslaw's Peugeot 307sw modding thread
