Old 05-07-2017, 12:32 PM   #11 (permalink)
Peugeot 206 1.4 HDi - '02 Peugeot 206
Last 3: 47.49 mpg (US)
Most cars in the United States come with factory recommend tow ratings, then the hitch you install also has weight ratings (because cars don't come with towing gear). Then you use which ever is lower.
The car may have a 2,000lb tow limit, the hitch may one be rated for 1,000lb. Or the car may have a 1,000lb limit but the hitch may have a 2,000lb limit. You have to go with the lower rating.
Then you have trailer limits and tire limits of the vehicle and trailer tires.
Aah okay, so it's about the same as in The Netherlands. The Prius anyway, isn't allowed to tow anything here. The hitch may only be used for a bicycle carrier.
Old 05-07-2017, 02:59 PM   #12 (permalink)
V8 guy
Shocker - '11 Nissan Leaf SL
90 day: 130.28 mpg (US)
Wow I didn't know the prius didn't have a tow rating.
In the U.S. if the vehicle doesn't have a tow rating here that means you better not tow anything or you better not get caught.
2011 leaf SL, white 240v evse mod, trailer hitch, new batt as of 2014.
Old 05-07-2017, 07:19 PM   #13 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
Last 3: 24.65 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 24 AUTO
Pickups
90 day: 22.62 mpg (US)
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
The Nissan Leaf has a 0 tow rating as well.
With the new SAE J2807 protocols I don't see to many eco boxes getting a rating. Any vehicle raited over 1500 must be equipped with a brake controller. The new rating system the vehicle must proform under real world conditions and be leagal. One specification is the ability to stop and start in both directions at max rated multiple times.
The standard outlines dynamic and performance criteria as it relates to a given vehicle (it applies to passenger cars, multipurpose passenger vehicles, and light-duty trucks up to 19,400 lb GCWR [Class 5]). Examples within it include various tests conducted while towing and mandates certain temperatures, speed, and accessories operating, including climbing the infamous Davis Dam Grade on the Arizona-Nevada border while maintaining 40 mph (64 km/h) for single-rear-wheel trucks and 35 mph (56 km/h) for those with dual rear wheels. Also included are a constant-radius understeer test while increasing speed and a sway maneuver using aggressive steering input.
1st gen cummins 91.5 dodge d250 ,16cm turbo housing ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 29.3mpg 97mi 3.311usg 7/27/16
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following User Says Thank You to gumby79 For This Useful Post:
Xist (05-23-2017)
Old 05-07-2017, 08:43 PM   #14 (permalink)
...beats walking...
Old Tele man's Avatar
Q: what happens when then european model(s) have trailering capabilities, but the exact same USA model doesn't, ie: current 2017 Prius ! ! !
2014 Toyota Prius 1.8L eCVT
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2011 Chevrolet LTZ Cruze 1.4LT 6A
1971 Dodge Charger 318 3A
1970 Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 05-08-2017, 12:09 AM   #15 (permalink)
V8 guy
The reason for the euro tow rating versus no US rating is:
Euros do the unthinkable, they actually slow down while towing.
They will put a break controller in a car, unthinkable in the US.
Most if not all of them have to have some kind of trailering class before they can tow.
So in the US everything need to be designed for idiots exceeding the speed limit with no trailer brakes while towing.
Fingie (05-08-2017)
Old 05-08-2017, 03:20 AM   #16 (permalink)
gumby79's Avatar
Team Streamliner
Pickups
Old tele
In Europe your insurance coveret the "leagal "trailing accident. In the us you broke the rules accepting full responsibility for your illegal choices and your ins gos up, Of the old man that you bump has a heart attack it could be murder charges. With the same car made for different markets, aka different specifications.
Duse the EU require proof of concept on tow rating?or is it a magic number pulled from a hat like the US used to be?
Can an EU prius pass the SAE J 2807?
Oil pan
How much was that load under the rating , that inspired you to rebuild your trailer with brakes this time.
. And the mild 800lb gross trailer weight was pushing the car around a lot more than I would have liked when I tried to stop.
. If any I'd say the magic rating number from the hat was high by the new standard. I think the SAE J2807 is more to force honesty out of the manufacturer. No more selling a truck with a 5/10,000lbs rating tow package that is only leagal for 1499lbs. Or needs a bigger radiator, trans cooler,etc
Former
87' Hyundai Excel
Old 05-08-2017, 04:19 AM   #17 (permalink)
The 2017 Prius has an towing capacity of about 750 kgs in the Netherlands. So that is not much. (about 1600 pounds?)
Old 05-08-2017, 08:00 AM   #18 (permalink)
V8 guy
Originally Posted by gumby79 View Post
Oil pan
Both cars are rated for 2,000lb. I was towing 800lb gross long distance and I noticed that it was pushing the car around any time I would try to stop.
Then when I was towing 1,000lb gross with my corvette brake equipped firebird I noticed the trailer pushing me around and I even locked up my ultra high performance summer only tires.
I read several articles on J2807, they all said exactly the same thing, except for this one, which actually quantified values.
http://www.tundraheadquarters.com/bl...ngs-explained/
Now I see why they refer to it as "that dam test".
It's going to absolutely murder a lot of these crazy tow ratings we see.
I'm sure my firebird could do it. I had no problems maintaining 75mph in 6th gear going over the mountains in Virginia and Tennessee on I-81 and I-40 with my trailer loaded with around 600lb.
Xist (05-23-2017)
Old 05-08-2017, 02:25 PM   #19 (permalink)
...beats walking...
The dichotomy between EU-spec'd towing capability and USA-NON-spec towing incapability reminds me of saying we had in Vietnam when we were issued GENEVA "Non-Combatant Cards", "...hold it up and see what caliber bullets it protects you against..."
In other words, it's just a "paper game", something to check the necessary "box" somewhere on some useless form.
Old 05-08-2017, 05:09 PM   #20 (permalink)
Renault owner
Fingie's Avatar
Tegybi - '97 Renault Twingo 1.2 Mpi
90 day: 43.07 mpg (US)
a guy here at 'yota said the HSD does not like excessive weight, and that the body isn't rigid enough in the long run of using a trailer.
And priuses until the latest gen are not allowed to tow here in eu area.
A trailer here has also mandatory insurance, it's separate from car.
If it has brakes, it must be inspected.
(trailer accidents rare here, though. I guess having some laws is good sometimes)
My war wagon can legally pull 400kg with non-brake trailer, and 1000kg with a braked trailer.
If you don't make any mistakes in your life,
life itself will be a f*ckup.
it's not your fault, Renault
jeep, pickup, prius, towing, trailer
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
