09-19-2014, 08:36 AM
#11 (permalink)
Rat Racer
Sometimes using the right wrong tool is better than using the right tool.
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
The Following User Says Thank You to Fat Charlie For This Useful Post:
09-19-2014, 01:12 PM
#12 (permalink)
Another thing to consider is that if a nut's rusted tight enough that using a normal socket* rounds it off, anything that grips tighter is likely to snap the bolt.
*That's the right size. Of course sometimes you have to deal with the result of someone using a too-big socket.
The Following User Says Thank You to jamesqf For This Useful Post:
09-19-2014, 03:25 PM
#13 (permalink)
09-19-2014, 05:01 PM
#14 (permalink)
Yes Freebeard, I have one of those, but it did not work when I needed it. Maybe this would not, either, but it is far smaller.
09-19-2014, 05:37 PM
#15 (permalink)
As Ive been working on my 95 suzuki sidekick I found its actually easy to just break the bolts and go to lowes and buy some new grade 8 1.25 m12 bolts.
09-19-2014, 08:03 PM
#16 (permalink)
Originally Posted by Cobb
...its actually easy to just break the bolts and go to lowes and buy some new grade 8 1.25 m12 bolts.
Sure, IF the bolt goes through whatever it's holding together, so you can push/drive out the broken parts. If it's a stud, you're SOL.
09-19-2014, 08:14 PM
#17 (permalink)
I drilled out a broken exhaust manifold stud on my 83 ZX without removing the manifold. Hundreds of studs but that one was the hardest. Normally we pulled the manifold to check it for warpage. Did not even have to tap that one.
regards
mech
09-21-2014, 03:07 AM
#18 (permalink)
herp derp Apprentice
Also available in wrench version
The Following User Says Thank You to 2000mc For This Useful Post:
09-21-2014, 08:44 AM
#19 (permalink)
One of the problems with those universal tools for removing stuck fastners is the fact they need a lot of clearance around the part in question. Many cases what I have is in a recessed location or requires removal of another part to get a better grab. This is where the dremel comes out. Once I got lucky and a blob of super glue helped. Im sure if you can weld that might be another ave to go.
PB Blaster also is the best spray for getting stuff loose. It looks like snake oil, but it works.
09-21-2014, 10:36 AM
#20 (permalink)
I am on my second can of PB Blaster. I wonder what tools I will see for sale this Black Friday, etc. It seems that Amazon had sales for at least a month.
