Old 07-22-2008, 10:50 PM   #1 (permalink)
Box Dreamer
xB Commuter - '04 xB
90 day: 40.76 mpg (US)
How to restart the engine by clutch smoothly?
I start EOC today and try to restart the engine by clutch. It is difficult to restart the engine smoothly. I tried different gears to pop, but the process is still rough. Anyone has a good advise?
Old 07-23-2008, 07:07 AM   #2 (permalink)
Boxhead
whokilledthejams's Avatar
Boxy Brown - '04 xB
90 day: 35.48 mpg (US)
Send a message via AIM to whokilledthejams
I don't bump-start all the time, but when I do, I try to be doing about 25-30mph, and bump start it in 5th. That way, when it does fire up, the revs don't climb really high. Also, as soon as the engine fires up, I disengage the clutch again, because at that point, I'm generally stopping anyway (if you saw my extremely low-traffic commute, this would make more sense).
Someone else here wrote up a much more elaborate, and probably better, bump-start technique, but I can't recall who that was.
Old 07-23-2008, 08:40 AM   #3 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
How to smoothly bump start / clutch start an engine
Old 07-23-2008, 02:21 PM   #4 (permalink)
Box Dreamer
Thanks for the link. I tried this morning and I can tell the big difference. Now, the engine restarts like a hybrid, very smoothly and unnoticed.
Old 07-23-2008, 06:38 PM   #5 (permalink)
greenitup's Avatar
Truck - '97 Ranger
90 day: 30.32 mpg (US)
when i first started it was rough but i have gotten better. just takes a bit of practice and the right gear.
Old 07-29-2008, 09:14 PM   #6 (permalink)
Troy - '94 Galant GS
90 day: 36.63 mpg (US)
Greenie - '94 Metro LSi
90 day: 55.23 mpg (US)
Not-so-Grand Am - '98 Grand AM GT
90 day: 32.04 mpg (US)
I give it a little bit of gas and let out on the clutch in whatever gear is appropriate for the given speed. I have tried this on Troy, the Geo, and the Festiva, and none of them have given me any troubles. When I pull out of my downhill/mountain drive way, I start the car using a bump start... so the engine is completely cold... still with no problems.
I'm not sure how to follow the information in the guide. It says to bump start in a higher gear than is appropriate for a given speed... well, for me, I shift at such low speeds it is probably already inappropriate to start up in that gear. For example, at 20 mph I am already in 4th gear. So should I be starting up in 5th? And regarding the extra engage/disengage... isn't this just causing extra wear and tear on the clutch? Is this really necessary if the car is already starting up with out a lot jarring?
bump starting, clutch starting
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 980 04-25-2012 10:12 AM
How to smoothly bump start / clutch start an engine MetroMPG Hypermiling / EcoDriver's Ed 75 05-24-2011 02:34 PM
Coasting experiment: engine on VS engine off on a fixed route = 12.9% gain MetroMPG Hypermiling / EcoDriver's Ed 6 02-22-2008 08:38 AM
DIY decel fuel cutoff; alternator regulation; auto start/stop MetroMPG EcoModding Central 0 11-29-2007 02:04 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
