How to smoothly bump start / clutch start an engine
This question comes up enough that it's worth a dedicated thread.
The goal is to re-start the engine at the end of an engine-off coast, while the vehicle is still in motion. You want to impart as little shock/wear to the drivetrain / passengers as possible. Don't ...
Note on the first "don't" - one instance where you might simply dump the clutch in the gear appropriate for your road speed is if you need the engine on NOW (maybe for safety reasons), and the extra 1.5 seconds to switch gears & rev match would take too long. With practice using this technique, "bump" starting should become a misnomer. Clutch starting the engine in this way should be nearly imperceptible to a passenger. |
Thanks for posting this. I for one was not sure on the specifics. But I haven't gotten to try this yet either.
Great post, I always wondered how people do this without wreaking havoc on the engine and drive train components. How does this method effect clutch wear though? It seems like using it to spin the engine while it's only half way engaged would wear the clutch much faster then normal. That then would bring into account the replacement price for a clutch into your cars operating cost.
Clarification: I wouldn't say it's only half-way engaged and slipping - just that you don't need to completely dump the pedal to spin up the motor, as the clutch is fully engaged well before the pedal is fully released.
Does clutch starting cause more clutch wear? Definitely. Compared to what, though? I doubt it's as much wear as would be experienced by people who commonly use their transmissions for engine braking, and slip their clutches each time they shift down to do so. EDIT: the choice of a higher gear for clutch starting also minimizes wear, since the input shaft is spinning slower when the clutch is engaged. |
It would be interesting to hear how often people who use this method of bump starting have had to replace their clutches in the past.
::EDIT:: You bring up a good point about the gear braking. My best friend has a '02 Mini Cooper and he has nearly 70k on it so far and just recently replaced his clutch a month or so ago for the first time. He autocrosses (races) this car every weekend so if it took 70k for him to need a replacement after racing conditions then I guess the point is null. |
I've been bump starting for years and have 465,000 miles on my original clutch.
Simaler to Frank Lee, I let it out in a simaler manner as I do when coasting down the driveway in the morning, and it's alwas smooth enough that the only thing a passenger notices is that the oil and battery light on the dash went out, I've heard of people who's passengers freak out, and if that is the case then they need to revisit what they are doing, or let someone else drive.
It's going to be different from car to car as well. Everyone here has probably driven enough different vehicles to know some are more forgiving than others.
Good writeup. I'd like to add that I was able to clutch start in 4th at ~5mph yesterday.
I wonder how much energy (in lost momentum) this is using vs. electrical energy that the starter would use, and if there is a significant difference. Prob not much of a difference. |
I think (don't know for sure) that some fuel-injected cars will add extra fuel when you crank the starter. Bumping would eliminate that.
