Old 04-04-2010, 08:20 PM   #1 (permalink)
EcoModding Alien Observer
suspectnumber961's Avatar
highcountryexplorer - '86 720 KC 4x4 ST with fiberglass cap
90 day: 20.51 mpg (US)
Elroy - '03 Focus ZX3 w/Zetec DOHC engine
90 day: 33.43 mpg (US)
How to test your gas for ethanol...
1) Buy a 10 ml graduated cylinder
2) Mark an extra 11 ml line above the 10 ml level
3) Add 10 ml of the gas you want to test
4) Add 1 ml of water up to the new 11 ml line
5) Put your thumb over the top and shake the sh*t out of it
6) Set it somewhere and let it settle
7) If you now see 1.5 ml of separated liquid at the bottom...you have approx 5% gasahol.
note...some of the separated liquid will stick to the sides of the cylinder...and I'm not totally sure the 1 ml of water is enough to draw out all of the ethanol....or whether it also draws out other elements of the gas.
Graduated cylinder - Wikipedia, the free encyclopedia
Carry on humans...we are extremely proud of you. ..................
Warning: There are unicorns about...DO NOT throw anything unusual into their enclosure...they might stomp it and also you if you are not quick enough.
The Following User Says Thank You to suspectnumber961 For This Useful Post:
5speed5 (04-05-2010)
Old 04-04-2010, 08:24 PM   #2 (permalink)
The Geo - '93 Metro
90 day: 45.16 mpg (US)
I think i'm going to have to do a test of all the gas stations around me, see who's lying.
Need some victums to help me confirm results Nerys EcoModding Central 17 05-12-2011 03:29 PM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 54 05-08-2011 10:19 PM
Article: Crude oil is getting cheaper — so why isn't gas? Frank Lee The Lounge 20 07-14-2010 01:06 AM
What's your best bet for an automatic? Crono EcoModding Central 16 10-22-2008 01:14 PM
