Old 05-10-2017, 04:45 PM   #31 (permalink)
teoman's Avatar
A3 - '12 Audi A3
That would be the obvious first choice. And frankly if you do not have massive grillblocks then squirting water will only improve efficiency slightly.
But i get stuck in traffic a lot . So not much airflow over the coils. In my case, i think it will provide a noticeable benefit.
Old 05-11-2017, 11:24 AM   #32 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 40.02 mpg (US)
90 day: 49.01 mpg (US)
Stuck in traffic shouldn't be a problem.
When using AC, the cooling fan defaults to always-on mode. There should be plenty of airflow even while stuck in a stack of traffic. Cleaner coils will help you tremendously.
That said, stuck in traffic with a bunch of other engines all dumping heat into the air is when you would want the misting system the most.
Old 06-30-2017, 06:23 PM   #33 (permalink)
teoman's Avatar
A3 - '12 Audi A3
I had another random idea. If a reservoir could be added for liquid state refrigerant, would that not increase the on and off times of the compressor?
In my type of driving I have to use the brakes fairly often, using ac compressor instead would be beneficial. The added capacity could cool me untill the next time i have to brake.
Kind of like adding a bigger battery for a regen system.
Old 06-30-2017, 06:27 PM   #34 (permalink)
teoman's Avatar
A3 - '12 Audi A3
Yet another random idea.
My car runs on lpg. And the lpg is injected in gas form.
If i route lpg through the cabin ac, i could get it to cool the cabin for free. Currently the engine coolant is used to heat/vaporize it.
Electric A/c conversion lovemysan EcoModding Central 15 08-28-2010 08:48 AM
Insulating cold a/c lines? CHEGAI EcoModding Central 18 06-30-2010 12:34 PM
A/C Recirc trikkonceptz EcoModding Central 5 07-31-2008 09:49 AM
Better fuel economy with windows cracked, or A/C? dann_04 General Efficiency Discussion 3 07-30-2008 11:26 PM
It's not just the A/C tasdrouille General Efficiency Discussion 4 04-17-2008 11:57 PM
