Old 05-18-2010, 09:58 AM   #1 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
this hurts my head
please don't tee off on me, I just am trying to understand this?
Old 05-18-2010, 11:08 AM   #2 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
dcb -
This is what they say :
SUPERLEGGERA HELMET :: Louis Garneau - $180
A new texturized front area simulating a golf ball effect creates a better laminar flow. The overall weight reduction and a forward move of the center of gravity will create less fatigue at the neck area in an aero position allowing the rider to maintain the aero position for a longer period of time and prevents the low head drag. The helmet is also equipped with 2 huge front vent inlets and 3 large back vent outlets for maximum airflow without compromising aerodynamics. The Superleggera is the featherweight of helmets, and is so light you forget you are wearing it. With the notable, Spiderlock Elite Retention System which uses a rack and pinion mechanism for quick and accurate adjustment using only one hand.
Does this require the head of the bicycler to be detached and spinning?
CarloSW2
American Solar Energy Society
The Following 2 Users Say Thank You to cfg83 For This Useful Post:
aerohead (05-19-2010), Frank Lee (05-18-2010)
Old 05-18-2010, 12:08 PM   #3 (permalink)
Remember the real function of the cool design is to sell product.
Working would be nice but is not essential
The Following User Says Thank You to smokeyj For This Useful Post:
Old 05-18-2010, 12:25 PM   #4 (permalink)
Moderator
tasdrouille's Avatar
The Guzzler - '08 Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '011 Soul 2U
To me, if the dimples were to work on such an helmet (can't say they do or don't without WT testing), Louis Garneau placed them probably in the worst possible place. You'd want the dimples where the flow is transitioning.
www.HyperKilometreur.com - Quand chaque goutte compte...
The Following 3 Users Say Thank You to tasdrouille For This Useful Post:
Frank Lee (05-18-2010), MetroMPG (05-18-2010), Tweety (05-18-2010)
Old 05-18-2010, 12:53 PM   #5 (permalink)
Out of my mind, back in 5
That was kind of my knee-jerk reaction too... If they in theory work, why put them in front? Other than that's where they are visible though...
Old 05-18-2010, 06:52 PM   #6 (permalink)
LegacyGT - '01 Legacy GT
90 day: 33.72 mpg (US)
It looks about right to me.
Although the air is still going to detach off the rider's back.
It looks like this may work well in conjunction with a small spoiler placed near the buttocks of the rider. Either a belt could be worn or perhaps an extension attached to the rear of the seat.
The Following User Says Thank You to majestic For This Useful Post:
MetroMPG (05-19-2010)
Old 05-18-2010, 08:39 PM   #7 (permalink)
Not to hijack the thread but if solid wheels at the rear aid aero then why not have them at the front as well?
Peter.
Old 05-18-2010, 08:44 PM   #8 (permalink)
2003 Ninja EX250 - '03 Ninja EX250
90 day: 87.63 mpg (US)
Saturn - '99 SL1 Base
Peter.
Because a solid front wheel can be dangerously unstable in side winds, and somewhat unstable from frontal winds.
Doing my part to reduce dependence on OIL
Doing my part to reduce congestion
And enjoying it!
If you have to use your brakes, you are driving too fast!
My 101.5 MPG 2003 Kawasaki Ninja 250
Crude Oil Price Today
Old 05-18-2010, 10:59 PM   #9 (permalink)
ECO-Evolution
Lazarus's Avatar
Iron Horse - '97 Intrepid
C-3 - '08 XF50X
90 day: 135.32 mpg (US)
It really depends on the rider position. In the pro peleton they spend an amazing amount of time and money on wind tunnel testing. These helmets can save about 10 watts at 25 mph. Does not sound like much but when 5 seconds can mean the difference between wiinning and losing it's huge. Every rider will have a different position on the bike so they have to find the helmet that works for that position.
A couple of interesting links with all the different helmets used in the Tour de Califronia and wind tunnel test.
http://www.active.com/cycling/Articl...California.htm
"Judge a person by their questions rather than their answers."
The Following User Says Thank You to Lazarus For This Useful Post:
Tango Charlie (05-19-2010)
Old 05-18-2010, 11:23 PM   #10 (permalink)
Bicycle Bob's Avatar
Appliance White - '93 Metro 4-Dr. Auto
Last 3: 42.35 mpg (US)
Stealth RV - '91 Sprint Base
Overall dimples are for creating TURBULENT, ATTACHED flow, not LAMINAR flow, on an object that rotates. They make no sense on a helmet, where a simple low ridge about 20% ahead of the maximum diameter does the job, leaving True laminar flow ahead of the ridge.
A lightweight helmet is nice for the neck, but moving the CG back would be better than forward.
This is marketing crap. If the protection is as sketchy as the prose, Darwin awards may be in order.
Head gasket seepage and blown headgaskets blueflame Off-Topic Tech 3 10-05-2009 04:26 PM
fuel useage of head lights? Ryland General Efficiency Discussion 14 03-07-2009 01:08 PM
Metro - carbon on the piston head? an0nymous Off-Topic Tech 71 10-06-2008 08:52 PM
Oil leak between head and block? SVOboy Off-Topic Tech 3 01-04-2008 07:03 PM
DIY - Head Swap (Project KDA complete!) SVOboy DIY / How-to 16 01-03-2008 02:17 AM
