Old 03-03-2011, 06:23 PM   #471 (permalink)
UFO
UFO's Avatar
Beetle - '01 Beetle GLS
90 day: 42.61 mpg (US)
4x4 - '89 Pickup DLX
90 day: 30.36 mpg (US)
I love it, the first paragraph on that linked site:
For many years people have been boosting their gas mileage by using hydroxy systems. By utilizing electrolysis you can break apart water into a mixture of gases called hydroxy and mix them with the fuel burned in an internal combustion engine. The result can be an increase in fuel efficiency, reduced emissions, more torque, and a smoother running engine. However, it has been a challenge to get the "mainstream" to take "hydroxy boosting" seriously.
No evidence yet of people "boosting" their mileage. This is still a hypothetical, and the text reads as if it was already fact. Nice catchy new word too, "hydroxy", much better than HOH or HHO or electrolysis, and obscures the origins making it seem new, yet again.
Further reading gives this gem:
The flow rate of HHO gas was measured by using various amounts of KOH, NaOH, NaCl (catalysts). These catalysts were added into the water to diminish hydrogen and oxygen bonds and NaOH was specified as the most appropriate catalyst.
What does adding a "catalyst" have to do with measuring a flow rate? And adding an ionic compound to water does absolutely nothing to "diminish hydrogen and oxygen bonds".
Pure hogwash. Not even the introduction to the abstract has any basis in reality let alone science.
"We think B20 is for suckers" N. Cowell, Denver B100
"Climate change denial is a conclusion in search of a rationalization" labman57
Old 03-03-2011, 06:50 PM   #472 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
tangomar -
Here is the conclusion from the thesis :
DESIGN AND APPLICATIONS OF HYDROXY (HHO) SYSTEM
http://library.cu.edu.tr/tezler/7998.pdf
6. CONCLUSION
The results of this experimental study are summarized as follows:
1. At mid and higher engine speeds, the HHO system with diesel fuel and gasoline yields higher engine torque output compared to pure diesel and gasoline fueled engine operation unless Hydroxy Electronic Control Unit (HECU) is added to the system. High burning velocity and low ignition energy of HHO-air mixture minimize the effect of the weakened in-cylinder charge flow and increased residual gas fraction which block the fuel to be fast and completely burnt at high speeds. Also, high burning velocity of HHO yields higher resistance against knocking which provides higher compression ratio (CR) and increased thermal efficiency. However, increased CR may cause pre-ignition and this can be minimized by direct HHO injection into the cylinder. At low engine speeds, low lean-flammability limits of HHO causes challenges at higher equivalence ratios. Due to the long opening time of intake manifold at low speeds, high volume occupation (reduced volumetric efficiency) of HHO becomes inevitable. Since minimum ignition energy of HHO-air mixture is a decreasing function of equivalence ratio till stoichiometric (richer) conditions, torque is reduced after HHO addition. A control unit has to be used to obtain appropriate electrolysis voltage and current (gas flow rate) to terminate the impairments of HHO gas at low speeds.
2. Uniform and improved mixing of HHO-air and oxygen content of HHO stimulate combustion which has a major effect on SFC by using an adequate capacity HHO system. Wide flammability range, high flame speed and short quenching distance of HHO yield gasoline and diesel fuel to be combusted completely under high speed conditions without HECU and low speed conditions with HECU.
3. High burning velocity, wide flammability range, oxygen content and absence of carbon make HHO gas an appropriate fuel addition to obtain adequate combustion which yield reputable reduction of HC and CO emissions when a sufficient HHO system is used at mid and higher speeds of engine without HECU and low speed conditions with HECU.
4. A control unit, which decreases electrolysis voltage and current automatically when the engine speed decreases under 1750 rpm for Compression-Ignition (CI) and 2500 rpm for Spark-Ignition (SI) (critical speeds for this experimental study), has to be designed and manufactured to eliminate the impairments of HHO enriched diesel fuel combustion at low speeds and to provide energy economy.
5. The average power increment in test engines during experiments is bigger than the electrical power consumed and fuel economy obtained with the aid of HHO system as well. This indicates that the system is efficient.
CarloSW2
American Solar Energy Society
Old 03-03-2011, 07:16 PM   #473 (permalink)
euromodder's Avatar
Hägar - '05 V50 1.6L Diesel
Diesel
90 day: 52.27 mpg (US)
Snert - '06 S40 1.6L Diesel
90 day: 58.06 mpg (US)
Read through the study quickly.
Point 5 seems weird, for I haven't found other references to their electrical setup in the study. I may have missed it, but I haven't even read wether the engine runs it own alternator to power the battery.
The claim appears out of the blue, with no data given - essential.
How the (claimed) atomic oxygen and hydrogen would survive the anti-backfire water jar that it gets blown through, is a mystery to me.
While atomic hydrogen and oxygen exist, they are very reactive and short-lived.
Lifetime fuel consumption :
Old 03-04-2011, 02:29 PM   #474 (permalink)
UFO
UFO's Avatar
H + H = H2. O + O = O2. No way to keep them apart. As if it would make a difference.
what do you think of hydrogen mods (with video) igo EcoModding Central 18 11-13-2008 01:54 PM
Hydrogen Less than Gas Arminius The Lounge 4 08-03-2008 03:48 PM
GM's new hydrogen car SVOboy Fossil Fuel Free 0 01-08-2008 01:34 PM
