Old 09-23-2009, 09:11 PM   #1 (permalink)
Whitey - '05 corolla LE
90 day: 31.33 mpg (US)
Send a message via AIM to blackjackel Send a message via MSN to blackjackel Send a message via Yahoo to blackjackel
Hydrolic jack broke, my car is stuck in the air! HELP!
Ok so I jack my car up and put it on those little jack stands that my hydraulic jack came with. When i come to jack the car back down the jack just wont go all the way up.
When I pump the handle down the jack arm goes up and when i lift the arm back up the jack arm goes down again.... so instead of constantly going upwards it goes up and down and does nothing now.
What do i do?
Old 09-23-2009, 09:24 PM   #2 (permalink)
oldscoob - '87 wagon gl/dr
90 day: 47.06 mpg (US)
knock the car over onto bricks/wood planks?
if the jack got it up there, try overfilling the cylinder with anything oil. it must have bled itself if no leaks to not work right again.
Old 09-23-2009, 09:27 PM   #3 (permalink)
herp derp Apprentice
saturn - '99 sc1
90 day: 35.67 mpg (US)
got a jack with your spare tire tools?
Old 09-23-2009, 10:45 PM   #4 (permalink)
didn't even think of that!!! ima go try that, i hope it can raise the car as high as the other jack i used, the other jack is hydrolic and it put it up pretty high!
Old 09-23-2009, 10:51 PM   #5 (permalink)
saturn - '99 sc1
just stack blocks of wood or something under the jack if it cant go high enough
Old 09-23-2009, 10:58 PM   #6 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Zombie Insight - '00 Insight MT
90 day: 62.82 mpg (US)
I'm glad to hear you used the jackstands, and avoided becoming this guy.
Worst case: you have to go get your jack warrantied before you can drive, if the little scissors jack + blocks won't do it.
Old 09-23-2009, 10:58 PM   #7 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
You need this guy's services:
Old 09-23-2009, 11:08 PM   #8 (permalink)
saturn - '99 sc1
or this guy
Old 09-23-2009, 11:34 PM   #9 (permalink)
McTimson's Avatar
The Turkel - '93 Tercel
90 day: 40.39 mpg (US)
Felix - '09 Yaris
90 day: 34.49 mpg (US)
Does the jack have a separate release valve? If it does, make sure it's tightened all the way...
Or, just put a block on top of the jack, to give you the extra clearance. If you ever need to jack the car up higher than the jack allows, then the blocks work for that as well, just make sure you use the jack stands.
Old 09-23-2009, 11:50 PM   #10 (permalink)
Blue - '93 Tempo
F150 - '94 F150 XLT
Don't fool around with any of that namby-pamby troublesome hi-tech junk in the future. Do it right.
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 980 04-25-2012 10:12 AM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 54 05-08-2011 10:19 PM
$500 and 30mpg car? possible? olderthanme EcoModding Central 6 07-15-2008 09:37 PM
OEM Air Injection, Yay or nay? Dane-ger EcoModding Central 11 01-14-2008 10:05 AM
Video: MDI Air car (compressed air powered) Lazarus Fossil Fuel Free 2 01-06-2008 11:37 AM
