Old 08-21-2009, 12:59 PM   #1 (permalink)
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
Hypermiling helped me make it home!
Yesterday the wife called and the van was overheating on the way back from downstate. About 70 miles away. So I headed out with 6 jugs of water. Found out the lower radiator hose had a steady drip even when not under pressure. Local Autozone didn't carry the hose. So I figured might as well do my best to get it home. Filled it up, left the radiator cap loose, heater full blast, and hypermiled the thing. Since less fuel burned for the same distance (and no lean burn mods) means less heat, it helped out a lot. Only had to stop once from the temp gauge rising because it ran low on water, then let it cool a bit, refilled, and headed home. Got 31 mpg first half of the trip, 33 mpg 2nd half.
Should be able to do even better than that once I fix it and don't have to worry about watching the temp gauge constantly.
Winter daily driver, parked most days right now
Summer daily driver
Old 08-21-2009, 07:02 PM   #2 (permalink)
Relevance is irrelevant!
bluetwo's Avatar
Civic EX - '00 Civic EX
Send a message via Yahoo to bluetwo
Lol, great story. Something similar actually save my butt once too.
I was driving a 6 wheeled delivery truck and half way home I realized I wasn't going to make it to the gas station at the rate I was going, (there was only one place I could fill up) so I turned off the AC and kind of baked the rest of the way. I literally rolled that big truck into the gas station JUST close enough to get the hose in the tank at the fully stretched position. I thought I was the luckiest driver on the road that day!
Old 08-25-2009, 10:36 AM   #3 (permalink)
Pishtaco
SentraSE-R's Avatar
Clean Green Toaster Machine - '06 xB
90 day: 45.81 mpg (US)
Thanks for the great story. Glad you made it back okay.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
Mean Green Toaster Machine
49.4 mpg avg over 30,375 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
45.8 mpg over 2235 miles, 164% of '08 EPA
Old 08-25-2009, 12:19 PM   #4 (permalink)
wagonman76's Avatar
Team Chevy
Thanks. I got the van fixed. Got new hoses, even though the old ones still looked fine. Turned out they were fine, except whoever installed the last set of hoses didn't put the clamp all the way on the hose before tightening it. Geez, how hard can that be? So the clamp cut through the little bit it was on the hose and the hose finally started leaking. If I had tools and daylight I could have just moved the clamp that night. I replaced the hoses anyway and now it runs good. 273k on it. Doesn't appear to be losing any water now so before winter I'll drain and replace with antifreeze mix.
Summer daily driver
Longtime Lurker Looking for Miles ZX40 Electric Micro van mods & information rmay635703 Fossil Fuel Free 46 03-15-2012 07:21 PM
Hypermiling Syndrome hummingbird General Efficiency Discussion 5 07-27-2009 09:15 PM
Tax credits to make your home more efficent. Ryland Saving@Home 3 04-10-2009 01:53 AM
My introduction to hypermiling the Smart Ptero Hypermiling / EcoDriver's Ed 12 10-28-2008 07:32 PM
Home Brew Challenge for Electric Geniuses (make a DIY electric motor controller) WaxyChicken Off-Topic Tech 42 08-19-2008 01:05 AM
