Old 07-11-2008, 07:49 PM   #11 (permalink)
Slow and easy
elhigh's Avatar
Josie - '87 Pickup
90 day: 30 mpg (US)
I had a junky '86 Excel once, wore out its ignition switch. The replacement said Toyota all over it. Fit like a champ.
You're not in front of me...
I'm 25,000 miles in front of you.
Old 02-27-2011, 01:39 AM   #12 (permalink)
Liberty Lover
johnlvs2run's Avatar
honda - '99 civic ex
chevy - '89 celebrity
. - '00 .
Originally Posted by Gregte View Post
I just made a kill switch for my vehicle that is basically 'plug-in' style. I soldered wires to the two conductors of a burnt out blade type fuse, then connected the wires to a toggle switch. I then removed the ign (ignition) fuse from the fuse box and plugged in my new switched fuse.
I also put an inline fuse of the proper value in one of the wires so that the ign circuit is still fused.
Will this work in my '89 Celebrity, and how does it work?
Does it turn off the fuel injectors and leave on everything else?
I'd like to use a toggle to make an engine kill switch, for driving around town, and EOC on trips.
Also I'm planning to get a newer car in the 1995-2005 range that will get much better mileage.
I've more or less always turned the ignition off at stoplights, and worn out a few ignition switches this way.
So I'm very excited to put a kill switch in the car!
Old 02-27-2011, 02:43 AM   #13 (permalink)
Smooth Operator
Old Yellar - '79 Tourer Drop-Hood Coupé
90 day: 30.63 mpg (US)
when my ignition switch fails i think i will install something like this
ignition switch start button and accessories switch , pilot light for ing and acc
Old 02-27-2011, 12:27 PM   #14 (permalink)
Liberty Lover
. - '00 .
Can you explain more in detail what that does, and how you connect it?
Old 02-27-2011, 01:56 PM   #15 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
johnlvs2run -
That's a push-button starter that is commonly used in racing cars. I think that the toggle switch has a safety cover to turn the black-rubber starter button "hot". Here are some instructions :
Pantera Push Button Starter Install
If you have a car that people like stealing, then this makes the car easier to steal. Break in, press button, go. In that situation you would need an additional hidden kill switch. In the above example you need a key to "arm" the starter button. Makes sense for installing in a Pantera.
I may need one of these in the near future. At least nobody wants my car, .
CarloSW2
American Solar Energy Society
Old 03-05-2011, 11:54 AM   #16 (permalink)
Empty Pocketed Ecomodder
Gen - '05 Liberty Sport
90 day: 22.09 mpg (US)
Blurry - '03 Focus SE
90 day: 35.31 mpg (US)
you can also wire it after the key ignition so that you still need the key to operate, it will just prevent the wear caused by the repeated cycling of the key.
Old 03-05-2011, 11:59 AM   #17 (permalink)
Originally Posted by cfg83 View Post
johnlvs2run -
Yep, the covered switch is the master switch, the black switch turns on the ignition (or kills it) and the red button is the starter. at least that's how it was on my dwarf car switch panel, which looked darn near identical to that one. the reason i had it wired that way was so i could kill the ignition, put the car in gear, and use the starter motor to propel the car into the trailer. this allowed very precise control of the car in a confined space.
Last edited by Joenavy85; 03-05-2011 at 12:02 PM.. Reason: read the description of picture when it was first posted
Old 03-05-2011, 01:22 PM   #18 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Originally Posted by 3rdgencivic View Post
Just food for thought:
A big heavy wad of keys will also wear out an ignition switch. Be sure to keep your car keys on a seperate chain from the rest!
I have a neighbor that works on cars. He said that my ignition switch is bad. To me, the symptoms sound more like a bad main relay of fuel pump since the car will turn over and has spark, but wont fire.
He says that this could still be caused by a bad ignition switch.
What do you guys think ? If the car engages the starter, I would think that the switch is fine.
How much play should there be in the switch ? I can juggle the key around slightly, but its not overly loose.
I'm concerened because I actually do drive with a wad of keys attached to the car key.
"You don't fail until you give up. You learn, and move on." - Christ
" Hypermiling is not going slow, it's driving with more intelligence." - UFO
Old 03-05-2011, 04:38 PM   #19 (permalink)
IMHO if the engine turns over just fine then there isn't a problem with the ignition, a fuel pump relay could be the problem like you said. i haven't pulled apart an ignition to see exactly how it's wired, so maybe there is a separate contact inside that activates the fuel pump relay. i would think there would only be one to minimize the number of contacts that can get fouled, but that's just me.
Kill switch for 88-95 Honda Civic/CRX/DelSol AndrewJ DIY / How-to 38 03-29-2012 04:53 PM
