Old 01-02-2012, 06:50 PM   #51 (permalink)
Hi all, first post.
For those looking for a safe way to show technique, I suggest Harry's Lap Timer w/ an iPhone4 / touch ($15 app). It's what I use with my co-driver to analyze autocross runs. It has the capability to log OBD2 data as well. Not sure, but you *may* even be able to pair with a bluetooth headset microphone while recording to capture some very effective instructional video. Its nice to be able to overlay the data you want vs. rely on it being visible in the FOV.
You can find some good videos of OBD2 data overlayed on video using this on YouTube. I would post some but am still below the 5 post minimum for links.
Old 01-03-2012, 05:27 AM   #52 (permalink)
Absent without leave.
Arragonis's Avatar
George - '011 Aygo Go!
Team m8
90 day: 54.54 mpg (US)
Mildred - '011 Prius T-Spirit
90 day: 45.97 mpg (US)
Originally Posted by kurzer View Post
of course, i did it myself.
the switch is an opener. the whole MPI is powered over a relais. the relais ground is connected to the ECU. this line ist cut open and the switch is inbetween. thats all.
the restart installation is not mutch more complicated. a normal car relais drives the starter. relais coil ground goes to a contact at the alternator. relais coil + goes to a clutch switch, further to a throttle switch, further to a service switch and than to switched power. thats it, basically. the black box, shown in the vid, is for batterie and first start supervision.
I'll take a look at the video in more detail, but the clutch switch is a neat idea - so it starts with the pedal being pressed ?
No longer here. Bye, and good luck to all.
Old 01-03-2012, 05:39 AM   #53 (permalink)
kurzer's Avatar
Knut - '07 Prius
90 day: 50.9 mpg (US)
Santa - '00 Santamo
90 day: 29.07 mpg (US)
even better than that! it starts if both pedals, clutch and throttle, are pressed. so u have to move the foots as usual. release the clutch slowly and put some throttle to go, and the engine kicks in.
kurzer Gruß
Prius II
Hyundai Santamo
The Following 2 Users Say Thank You to kurzer For This Useful Post:
Arragonis (01-03-2012), Piwoslaw (01-04-2012)
Old 01-03-2012, 06:09 AM   #54 (permalink)
Arragonis's Avatar
Team m8
Superb.
