Old 10-02-2008, 07:26 AM   #1 (permalink)
Walkerjody
Neo Geo 2.0 - '96 Metro LSi Sedan
90 day: 39.89 mpg (US)
Hypermiling w/ an automatic tran?
Hello,
I am new to the whole hypermiling thing. I own a 1996 Geo Metro Lsi Sedan w/ an automatic transmission. I've just had to replace the engine, and I do not want to damage the new one. Can anybody give some tips to save gas w/ an automatic transmission? Is it safe to pulse n glide w/ an automatic transmission ... ie: I'm not talking about turning the engine off. I'd most likely just keep the engine on, but shift down to neutral on hills, etc. I do not want to cause any damage to this new engine. Thanks in advance. I'm enjoying re-learning how to drive. haha. Thanks.
Old 10-02-2008, 08:06 AM   #2 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Welcome to the site.
Using pulse and glide with engine on in neutral is just fine and won't damage your engine in any way. It will wear our your transmission slightly faster, but probably not more than a lot of city driving would do (lots of shifting). Other than that, definitly check out the 100+ hypermiling tips for more ideas.
Old 10-02-2008, 09:36 AM   #3 (permalink)
Kawi - '04 Vulcan 800 Classic
90 day: 56.48 mpg (US)
The Monte - '99 Monte Carlo Z34
90 day: 26.52 mpg (US)
Welcome. We always like seeing new people. I have a Monte Carlo that is automatic, and my wife's Elantra is automatic and I Pulse and Glide (P&G) with them all the time. Daox is right, the wear is not on the engine it's on the transmission, actually wouldn't there be less wear on the engine because you are running lower RPMs and coasting more. Well have fun, you'll be surprised how far you can coast in neutral, especially down a small hill.
Goal one= 30mpg on The Monte by changing the nut that connects the steering wheel to the seat.
Old 10-02-2008, 10:16 AM   #4 (permalink)
99metro's Avatar
putt-putt - '99 Metro Base
90 day: 58.76 mpg (US)
Dusty - '89 Bronco XLT
90 day: 13.89 mpg (US)
Cowboy - '90 Bronco XLT
90 day: 17.42 mpg (US)
HayHauler - '06 3500 ST
90 day: 18.03 mpg (US)
Coast in neutral A LOT. Coast up to stop signs in neutral from a ways - like 1/3 mile - from 55 mph. Don't go over 55 mph. You might want to invest in a Scangauge, or other real-time MPG device. It's darn near mandatory for the best fuel economy.
I have been P&G my other 3 vehicles with automatics. It takes some work, but doable. All my "glides" have been in neutral. You will be able to do MUCH MUCH better than 37mpg!
2006 3500 Dodge QC/FB 5.9 handshaker
Old 10-02-2008, 11:34 AM   #5 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Corolla LE
90 day: 35.55 mpg (US)
I P&G in my auto all the time. I even EOC now and then at highway speeds, which I know is horrible but I do it anyway. Neutral will do you just fine.
Old 10-02-2008, 04:19 PM   #6 (permalink)
Impala - '04 Impala base
90 day: 29.81 mpg (US)
Have done a little of P&G with my Impala, but have had to end the EOC due to a security glitch that sometimes crops up and does not allow me to restart the vehicle for about 8 minutes. Timing and coasting will definately help you out, even if you dont coast in neutral or do the EOC. Good luck.
Old 10-03-2008, 12:52 AM   #7 (permalink)
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.02 mpg (US)
IMA - '010 Insight EX
90 day: 45.43 mpg (US)
Tessie - '06 TSX Base
90 day: 28.83 mpg (US)
I've done it in the last 3 years or about 40K miles. I haven't seen any problems with it. Starter cranks, transmission shifts firmly -- but is aging and has some quirks (140K miles). It really improves FE, for sure...
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
Old 10-03-2008, 07:41 AM   #8 (permalink)
Walkerjody
Thanks everybody. I Pulse n Glided all the way to work this morning, 67 miles - yes, looooong commute I know. Anyway, everything seems to be going very well. I'll keep y'all posted after I fill up, etc. tonight. I was a little weary of trying P&G again, since my last engine broke down. I'm not sure why it broke down, but I cannot afford that happening again ... EVER. So it seems safe to do this, as long as I do not cut the engine off, from what I've read, etc.
Old 10-03-2008, 07:51 AM   #9 (permalink)
99metro's Avatar
My one-way commute is only 55 miles. With an automatic, you shouldn't turn the engine off (of course) - tranny pump won't work. Glad to see you got back on the horse with automatic tranny P&G!
IF you ever have to replace the engine, I'd suggest a JDM engine. It's a bit easier on the wallet and, IMO, well worth it.
Old 10-03-2008, 07:58 AM   #10 (permalink)
Walkerjody
Hopefully I will never have to replace the engine again ... haha NOT a fun experience. We looked at all our options, and for my model we had to go w/ a Jasper ... went fairly well, and the warranty is outstanding.
Why I'm Choosing a Civic Over a Metro Wayneburg General Efficiency Discussion 43 03-02-2011 05:11 PM
Poll: MPG before and after hypermiling peterj Hypermiling / EcoDriver's Ed 36 04-23-2009 06:16 PM
Regarding the free Hypermiling Safety Decal GoodPress4Hypermiling Hypermiling / EcoDriver's Ed 23 04-14-2009 04:59 AM
EMAIL friends results to PROVE hypermiling works mush3gan Hypermiling / EcoDriver's Ed 8 07-23-2008 03:24 PM
Metro automatic trans mod. engineer93065 EcoModding Central 15 07-02-2008 01:01 AM
