Hyundai may be inflating MPG figures - UPDATE: busted by EPA
Here's a good article on the discrepency between posted MPG figures and real life results from owners of the Elantra.
...GM needs to do the same thing (damage control) about the MPG differences for the automatic Cruzes between EPA and real-world customers!
...the "manual" tranny Cruze owners seem to beat their EPA numbers easily, while the "automatic" Cruze owners seldom even meet their EPA numbers. |
Here is a recent analysis that I performed based on comparing EPA numbers to fuelly.com numbers for cars rated at about 40 mpg.
http://www.crzforum.com/forum/member...d-december.png Hyundai way underperforms their EPA numbers; Honda seems to outperform. |
I beat EPA (in 11' Sonata) before learning to drive more efficient.
EPA City-24 Highway-35 Combined-28 First ten tanks averaged 31.2 or so, and the last ten is around 37. Have not had a combined tank under 35 in a long time now, and I probably can do better. |
I can't see the EPA being involved in some kind of conspiracy here.
However, I can see how a vehicle manufacturer could design a vehicle's propulsion equipment/algorithms such that the vehicle achieves overly optimistic, read not easily reproducible in the real world, MPGs on the EPA test cycle. I think that most folks either don't know or forget that the MPG numbers coming out of the EPA testing are intended for direct comparison purposes. The EPA numbers are an estimate based on an arbitrary test cycle. They are not a guarantee of anything meaningful. Given the infinite different driving conditions and driver capabilities/commitment, the EPA estimate does not necessarily predict any particular driver's MPGs. With a large enough random sample, drivers of vehicles with a 30 MPG EPA estimate will most likely see greater MPGs than drivers of vehicles with a 20 MPG estimate. If the EPA estimate is taken as an average estimate, half the drivers of a particular car will exceed it, and the other half wont. Which half would you expect to self-select to raise a ruckus? |
E-on-C and drive smarter, but the car could do much better with some simple reprogramming based on what the UG tells me. 2 small changes would probably net 3-4 mpg better.
If you are interested in MPGs then the only relevant comparison is from real-world MPG numbers. Those numbers are hard to come by; but less so with websites 'crowd sourcing' MPG numbers. |
Of the cars that are listed, the Hyundais do tend to be a bit "sportier," and I wouldn't be surprised if some of those low mileage numbers are caused by the owners' driving habits.
Self reported BS. All this tells us is which driver's are the biggest liars. I'll take the EPA test numbers over a bunch of self reporting nitwits any day.
