I basjoosed my headlights today (sealed the surrounding gap)
basjoos (v.) - to make aerodynamic optimizations at a micro (vs. macro) level.
(OK, yes, obviously basjoos does macro too, but whenever I start nitpicking about some small aero detail, I instantly think about his silicone-filled panel gaps. The "basjoosed panel gaps".) --- http://ecomodder.com/forum/attachmen...7&d=1197476035 So, no, I don't have any pics to post yet, but today I bought a roll of 3 mm (about 1/8) thick peel 'n' stick weatherstrip because I was looking for a quick 'n' clean aeromod project to do before my next big one. I fit the foam strip in the gap all around the driver's side headlight assembly. (I'll do the other side tomorrow.) That gap ultimately leads into the engine compartment and under the car, so despite it being a small area, it's pretty much the top of the list in terms of where I don't want air to go unnecessarily. I calculated a total open area of 43.2 cm2 around both lights, or 6.7 square inches. Inconsequential? Mercedes didn't think so ("sealed joints on headlights"): http://ecomodder.com/forum/attachmen...1&d=1204235894 From thread: http://ecomodder.com/forum/showthrea...5-up-1221.html |
Wow... 0.25 Cd. I wonder how much of that is because of the FULL SMOOTH-SURFACED UNDERBODY PANELING? :D Looks like they don't consider the hubcaps a priority, opting for weight over aero.
I never gave that gap much thought but now that you mention it and seeing that pic... you're making me a believer. I recently removed my ad hoc smooth hubcaps and rear skirts because they weren't having any effect on my routes but this sounds easy/small enough for me to squeeze in before I get back to my real job of schooling. Does Prius have a "show me" diagram like that? I'd be interested in seeing all their upgrades, plus those from the Volt. Time to call upon the mighty search engine gods! |
There was some slight noise reduction but it didn't translate to my scangauge. I will need more testing though under more optimal conditions. The wind lately has been annoying (HEADWIND???) and another reason I needed to remove all the tire tape was because I was getting my tires rotated today. :D
Got a lot of questions about my grill block though... blue tape does that. |
When I was fixing my inner fenders on my TDI (replaced one, coroplast-patched the other), I noticed that I could see HUGE gaps between my headlights and bumpers. I ended up stuffing 1/2" x 7/16" weatherstripping into the gap below.
If I need airflow into the engine bay -- well, that's what the vents for the Radiator and Intercooler are for, not "extra" venting via the headlights. No idea what improvement it's doing at this point, since I'm still calibrating my Scanguage II. That said, I know sealing that up that gap into a dead space shouldn't be counter productive. |
azrealswrd: Ben suggested I use lime green tape for my temporary mods. Nuh uh. :) I bet your blue tape got lots of attention.
The fact that you thought it was quieter tells me that's probably a worthwhile aeromod. ChristphrR: well, I did the other light this evening, and measured it. Total gap area (projected) around both headlight assemblies is 43.2 cm2, or 6.7 square inches - practically the size of a business card. I figure: if I've got a business card sized hole smack in the front of my car that does nothing functional, and ultimately lets air into the aerodynamic torture chamber that is the engine compartment/underbody area, why wouldn't I cover it up? GM obviously thought it was worth putting speed tape over the headlights (and other panel gaps) to squeeze max efficiency from the GM EV1 / Impact for its record setting speed run: http://ecomodder.com/forum/member-ae...-duct-tape.jpg Will post pics of my weatherstripping mod in a few minutes... |
I seen that on Christine when doing the front grill block (bumper block) and was surprised at all the air gaps! I was not at all concerned with an entire blockage after seeing all this..............
http://i75.photobucket.com/albums/i3.../grille013.jpg |
5 Attachment(s)
Pics:
http://ecomodder.com/forum/attachmen...1&d=1219712622 Above: the gaps! It's no Lexus. http://ecomodder.com/forum/attachmen...1&d=1219712428 The 3 mm weatherstripping. I cut this in half, width wise. http://ecomodder.com/forum/attachmen...1&d=1219712428 This worked out quite nicely: the strip was just the right size so I could position it in the gap and peel the backing off with it staying in place. Then I lifted up on the bumper to squish the adhesive down nicely. http://ecomodder.com/forum/attachmen...1&d=1219712428 Top view: the hood presses lightly against this. http://ecomodder.com/forum/attachmen...1&d=1219712428 No more business card size hole in the front of the car! Mercedes, eat your heart out. I need to finish the quarter panel gap around the side marker portion of the assembly. I'll just use black silicone there since it's too small for the foam strip. |
And MetroMPG - nice picture showing the before, during, and after. The size of the gap under your lights looks a lot like what I saw under my car (different make and all). I used a broken DQ Blizzard spoon to help shoehorn my weatherstripping under the lights, sticking it to the bumper fascia on the bottom, and sticking the top weather stripping to the plastic lense, again, like you did. |
