09-10-2009, 09:59 PM
eco....something or other
I find it interesting that nobody mentioned
the fact that removing the A/C condenser improves radiator flow....why?
I might be able to block more of my grille now with it out.AND I CERTAINLY HAVE MORE ROOM TO WORK ON THINGS!!!!!
1991 F-250:
4.9L, Mazda 5 speed, 3.55 10.25" rear.
The Following User Says Thank You to IsaacCarlson For This Useful Post:
09-10-2009, 10:03 PM
...beats walking...
...assuming you haven't already removed the a/c system, removing the condenser radiator kinda/sorta puts the a/c system on the "fritz."
...however, yanking it ALL out of the car can reduce weight by up to 100-150 lbs, which should be good for another 1-2% FE!
• 2011 Chevrolet Cruze LTZ 1.4LT 6A
• 2009 Pontiac Vibe 1.8L/SFI 4A
• 2004 Pontiac Vibe 1.8L/MFI 4A
• 2003 Ford Focus ZX5 2.0L/Zetec 4A
• 1971 Dodge Charger 318 3A
• 1970½ Plymouth AAR 'Cuda 340/6BBL 4M
• 1968 Dodge Charger 383 3A
• 1967 Plymouth Barracuda Formula S 383 4M
• 1965 Plymouth Barracuda Formula S 273 4M
09-10-2009, 10:37 PM
needs more cowbell
ac, who needs it. funny how something frivilous that was like non-existant 40 years ago is a "need" for the generations who never lived without it.
09-10-2009, 10:40 PM
...beats walking...
...50-60 years ago, I'd agree; but there were plenty of a/c's sold in cars in 1969!
09-10-2009, 11:23 PM
100lbs is pushing it for the AC system....it's mostly aluminum, at least it was in my car. The entire system in my car (compressor, condenser, radiators, and misc. plumbing and wiring) only weighed a little over 30lbs. Granted, that's for a 2 door Tercel, but I can't imagine it being too much heavier for a larger car.
The major difference for me when I removed the AC stuff was the realization that my radiator was in terrible condition. The AC radiator was covering up all the damaged/missing fins in the coolant radiator, so I couldn't really tell how bad it was.
As far as whether or not you need AC - there were maybe 2 weeks in this entire summer that I second-guessed my decision to remove the AC. I'm guessing that in Wisconsin, it probably would have been less than that. That's only 4% of the year - and I didn't even open the windows for those 2 weeks. Opening the windows alone would have been more than enough for me, if not, some type of portable fan would have sufficed.
If I were in a hotter climate, my feelings would probably be a little different. I get very claustrophobic in hot, humid areas, so if I was living in somewhere unbearably hot, I'd probably leave some sort of AC installed. But up here in NY, it's really not necessary.
Moderate your Moderation.
I don't use it often, but some days, I turn it on for a few minutes... mostly when someone else is getting in my car, though. I cool it down a bit for them, but after that, it's windows down, head out the window, panting and gasping for air.
While I'm doing the 007 work on the Van, I plan on removing the A/C, I think... and probably installing a wet HVAC system for evap cooling when necessary.
09-11-2009, 03:56 AM
marcusmodder
Replace ac in that quote with alternator I'm right with you. Ok, you have to change the whole quote but you get what I mean.
One day people will start saying the same thing about a vastly more wasteful luxury, the alternator which is on all the time. I decided to keep my A/C and use it guilt free the few days of the year when I'm stuck in traffic. I figure I've earned it.
Having said that, the less the better.
Good on ya, I.C. Ha, your initials are I.C, and you are removing your A/C which is Icy. What am I drinking?
09-11-2009, 09:58 AM
Eco Noob
Down here in Atlanta - AC is something that we cannot really do without.
Granted i almost never turn mine on due to...
AM commute - car is "Cool" from overnight low temps
PM commute - car is parked in covered parking deck ( first available spot, facing OUT for quick exit)
But on weekends if driving somewhere with SWMBO - the AC comes on.
So for that reason - It has to stay in car....
Steve - AKA Doofus McFancypants
"If there's a new way, I'll be the first in line - But it better work this time"
 First Milestone passed - 30 MPG (city) 5/15/08
Best City Tank - 8/31/09- 34.3 MPG (EPA= 20)
Best Highway Tank - 5/20/09 - 36.5 MPG (EPA= 28)
In effort to drive less:
Miles NOT driven in 2009 = 648 (Work from home and Alt Transporatation)
09-11-2009, 12:29 PM
#9 (permalink)
That is a good point that I hadn't thought about. Considering the only vehicle in my driveway with working AC is the Celeb. I might be able to remove the condensor from the 6k wagon and block off both grilles. Also might be able to remove the condensor from the van and increase cooling when towing. I use a fan over the trans cooler than runs full time with the fuel pump.
Winter daily driver, parked most days right now
Summer daily driver
09-11-2009, 12:38 PM
#10 (permalink)
Moderator
When both cars are parked in the sun there is a huge difference in temperatures inside my TDI with a light tan interior vs our inside out black Elantra.
