12-01-2008, 12:21 PM
I got worse fuel mileage with a grill block
I put a cheap grill block on my jeep(plastic sheeting and duct tape.) I wasn't able to do a formal A-B-A test on it, but it was mostly a proof of concept to see if the vehicle would over heat. I left it on for a trip to Montana recently. On the first two legs, I posted 14.9 and 16.1 mpg. This is the worst hwy mileage I've posted since I began hypermiling the jeep. Both of these were level stretches of freeway with some rolling hills. I removed the grill block for the rest of the trip and mileage improved to 18.4 on the next leg. The next leg was windy mostly two-lane, and a had an approximately 3 mile 6% grade in it. I know this isn't a very scientific test, because the roads changed between runs, but I would think the third leg would be worse for economy than the first and second. Also, the fourth leg was very similiar to the first and second and I again was over 18. I have two hypotheses for these results:
-The grill block decreased airflow too much, so the fan worked more and the extra drain on the engine canceled out any aerodynamic savings.
-Either myself or the road introduced enough variation that the test is just invalid.
Has anyone here had experience with grill blocks on 97-2006 Jeep Wranglers(TJ series)? If you have, what effects did you notice on fuel mileage? I'd like to gather some more info on this vehicle before I run more tests of my own. If I cant get anything, I'll probably run the block again with a larger opening too see if I get different results.
12-01-2008, 12:38 PM
I think that's it, in a nutshell.
Not saying the idea that over-blocking the grille couldn't reduce mileage, but the driving you did isn't a "test".
There are a number of Jeep owners who have grille blocks. Hopefully they'll chime in with their experiences.
12-01-2008, 12:42 PM
honestly I dont think a grill block on a jeep will do much beside overheat the engine. if you have the 4.0 I6 especially, that engine runs hot. the front of the jeep is essentially a brick, the holes in the grill might even allow enough air to pass through to make it a smaller brick aerodynamically
12-01-2008, 12:44 PM
Hello,
A headwind / tailwind could easily explain the change? Do you have a picture of your grill block?
12-01-2008, 12:58 PM
I didn't have a noticeable change in winds. No I don't have a picture, but it was just clear plastic sheeting stretched across the grill with duct tape  holding it on. I cut out the plastic over the center grill slot for airflow.
12-01-2008, 01:04 PM
Nope.
12-01-2008, 04:54 PM
93Lx - '93 Thunderbird Lx 90 day: 20.64 mpg (US)
I had blocked approximately half the radiator on my Thunderbird in an initial temperature test for aeromods/trying to get it to OT faster. I discovered I couldn't reduce the airflow that much due to the clutch fan engaging frequently and dropping the mileage like a rock.
No data for me or you for sure but I could hear the fan in my situation.
12-02-2008, 09:24 AM
My dakota quad cab looks a lot like the jeep to the on coming air. I took off my clutch fan and totally blocked the upper grille. This netted me about 1-1.5 mpg. I'll probably have to install an electric fan after this winter, but so far I have had no overheating problem.--It's a 3.7L
12-02-2008, 12:39 PM
#9 (permalink)
I've got all but about 1 of the openings blocked right now. Great for winter time warm up. So far I haven't had any problems with it getting too hot. Summer time I had 4 of the openings blocked and the only time it kicked in the fan was when we saw temps over 95F with a lot of stop and go in town driving(then again what car won't). Haven't seen a drop in mileage. I've done several mods at once so I'm not sure how much it improved it. But I do remember after putting them in I noticed it pick up speed faster going down hills. So I guess my butt dyno says its helping.
Adjusted for my driving habits. 80%city/20%Highway.
20mpg city/30mpg highway or bust! Check out my mods so far
12-03-2008, 01:20 PM
#10 (permalink)
I did a simple cardboard grille block on a '97 dodge ram (which has a HUGE grille) and saw 2mpg, or about a 10% improvement. I did the same thing to my Chevette, which is shaped like a small brick and saw no improvement. So I think it depends on the vehicle. Grille blocks help some more than others.
1982 Chevette diesel  36 hp at the wheels, best 59.6mpg.
1989 Dodge Diesel 972rwhp, 27mpg.
1971 Nova tubbed, solid cam 355 w/nitrous, really bad fuel economy.
