Old 12-06-2012, 11:21 PM   #1 (permalink)
HydroJim's Avatar
Aerofocus (retired) - '00 Ford Focus ZX3
90 day: 44.66 mpg (US)
The Red Baron (sold) - '93 Geo Metro
90 day: 44.1 mpg (US)
Small Wheels
I'm currently designing a reverse trike and I am looking for a lightweight front suspension set-up with thin wheels to save weight, reduce frontal area, and reduce rolling resistance.
Here is an example of what I'm looking for:
Unfortunately, this guy's donor car is not available in the US.
I was thinking motorcycle wheels might do the trick, but I can't visualize how I would attach one to control arms.
Any ideas please let me know
Aerospace Controls Engineer.
Currently driving a mostly stock 2014 Mitsubishi Mirage DE hatchback.
Old 12-06-2012, 11:28 PM   #2 (permalink)
Jimmy - '00 GMC Jimmy SLT
90 day: 21.18 mpg (US)
The White Gnat - '99 Suzuki Swift
Team Suzuki
90 day: 51.87 mpg (US)
I don't know the sizes, but what about the skinny wheels they use on the fronts of dragsters, and then the motorcycle tires on them?
Old 12-07-2012, 12:37 AM   #3 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
That photo is of a motorcycle wheel, I haven't heard of anyone having one fail yet, but they are also not designed for sideways stress! the tires are not either.
Mounting them to the control arm would be easy tho, it's a simple spindle/bolt, of course the bearings are not designed for thrust loads so those will have to be replaced as well, tapered roller bearings would work well.
Other option would be the narrow rim from an old VW bug, narrow tires too, VW Brakes – Dune Buggy Braking Systems | AppleTreeAuto.com cheap too!
a number of older rims are out there, ones from a bug are $10 at a local junk yard, or you could get new front race rims and pay $150 each, 145/65 R15 tires are also sold in a LRR tire, pretty sure those are the same tire the Smart Car uses on the front, seems like a perfect fit!
Old 12-07-2012, 07:01 AM   #4 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
He has a point, they are meant to lean into a turn. You could make a tilting trike. Maybe set of alloy temporary wheels.
Reverse Trike Motorcycle Club
http://forums.vwvortex.com/showthrea...5478-Odd-Trike
http://www.youtube.com/watch?feature...&v=CUT3imO17qE
- Tony
Old 12-07-2012, 09:45 AM   #5 (permalink)
Ryland's Avatar
There are of course other brands of vehicle front ends that you can get for building hot rods, I would suggest using something like this because it gives you solid proven wheel bearings, lets you use standard bolt pattern wheels and it gives you options for off the shelf brake parts.
front+spindle - JEGS High Performance
It would be nice if you could get something from a Smart Car, but they have an odd 3 lug wheel.
Old 12-07-2012, 10:03 AM   #6 (permalink)
The road not so traveled
TheEnemy's Avatar
The Truck - '99 Nissan Frontier xe
90 day: 25.74 mpg (US)
The Ugly Duck - '84 Jeep CJ7 Rock crawler
If you can weld you would be able to build it from scratch, which is what it looks like is being done in the photo.
Old 12-07-2012, 10:39 AM   #7 (permalink)
https://www.lefthanderchassis.com has some suspension parts, obviously intended for track racing but it's worth browsing anyway.
Work From Home mod has saved more fuel than everything else put together.
Old 12-07-2012, 12:18 PM   #8 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
Why not use CRX running gear and narrow a steel wheel? Just do it like they do to widen them, but cut the barrel down instead of adding new material.
Old 12-07-2012, 12:45 PM   #9 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 587.16 mpg (US)
Send a message via MSN to jakobnev
It might be possible to have a steering geometry that tilts just the front wheels into turns. (no need to tilt the whole cow)
