Old 07-31-2014, 07:54 AM   #21 (permalink)
backpacker3's Avatar
Homer - '02 Pontiac Sunfire SE
Team Pontiac
90 day: 30.05 mpg (US)
I was figuring that it could get in through the center hole that allows clearance for all the components going to the wheels
Aiming for 50 MPG from an automatic.
See how I'm doing here, My Build Thread
Old 07-31-2014, 01:54 PM   #22 (permalink)
Jimmy - '00 GMC Jimmy SLT
90 day: 21.18 mpg (US)
The White Gnat - '99 Suzuki Swift
Team Suzuki
90 day: 51.87 mpg (US)
Where I live it's pretty dry, and although we get rain & puddles, it's not a daily (or even weekly) occurance. I would say, if you're afraid of water getting trapped in there, about 3 small "drain holes", maybe 1/4" to 3/8", near the edges of your discs should do it. The centrifugal force of the wheels spinning should pump it out of those drain holes in short order, and the aerodynamic penalty should be minute. Even notches cut into the edges of the discs might work even better for that.
Old 08-10-2014, 08:27 PM   #23 (permalink)
The donkey CRX's Avatar
MULE VX - '92 Honda civic VX
90 day: 92.6 mpg (US)
White 94 VX "Show Car" - '94 Honda Civic VX VX
90 day: 79.92 mpg (US)
The Walrus - '02 Honda Insight base
Gen-1 Insights
90 day: 100.88 mpg (US)
cheap inside wheel covers
Here is how I covered the inside of my Insight space saver wheels on the red VX to make them more aero. These are the wheels I put the vinyl covers on the outside to make them smooth and aero. Since I used supplies I already had on hand I think I will see a breakeven in MPG in at least 15 years.
There were 4 "holes" that were larger than the foam ring, so I duct taped them before I inserted the foam ring on the wheel
So far (1500 miles) centrifugal force is all that is needed to keep the ring in place.
Outside of this wheel
The Following User Says Thank You to The donkey CRX For This Useful Post:
aerohead (08-11-2014)
Old 08-10-2014, 09:53 PM   #24 (permalink)
Team Pontiac
Cool!
