Old 07-15-2008, 01:16 AM   #21 (permalink)
Box Dreamer
xB Commuter - '04 xB
90 day: 40.76 mpg (US)
That's a good idea. I can't wait for election and get those free corplast. heheh.... By the way, does it affect the ventilation and A/C temperature? I already feel the hot air blowing into my cabin without A/C on these few days.
Old 07-15-2008, 08:03 AM   #22 (permalink)
Boxhead
whokilledthejams's Avatar
Boxy Brown - '04 xB
90 day: 35.48 mpg (US)
Send a message via AIM to whokilledthejams
It hasn't affected anything that I've noticed. The fresh air vents are up in front of the windshield, it's just the AC condenser that's down in front of the radiator. Either way, the fan is behind it pulling air, so I think any flow that's lost is relatively trivial. I might experiment with the upper grille blocked instead of the lower one, though, just to see if it makes a difference which one I block.
Old 07-15-2008, 10:36 AM   #23 (permalink)
2k2Prot5 - '02 Protege5
90 day: 33.82 mpg (US)
Originally Posted by Cd View Post
( At Lowes, we carry the same stuff as Home Depot.) The largest size that you would have found would have been really small anyways.
This weekend I bought a 4x8 sheet of coroplast from HD for 20 beans. Installed it under my track car. Went on easily, so i may do the same for my DD.
Old 07-15-2008, 04:22 PM   #24 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 45.16 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Hello,
I'm going to get a sheet from a local sign shop for $20. It'll be one of the dark blues.
S!gn Logic in Hudson MA
BTW, is it "Coroplas" or "Coroplast"?
Old 07-15-2008, 04:39 PM   #25 (permalink)
Mr. Blue Tape
azraelswrd's Avatar
AzxA - '06 xA
90 day: 42.72 mpg (US)
Coroplast is the trademarked name so I go with that spelling.
My 5 pillars of fuel efficiency:
  • driving style
  • aerodynamics
  • tires
  • weight reduction
  • engine maintenance
Old 07-15-2008, 04:45 PM   #26 (permalink)
Josepha - '08 xD
Hey, check this out:
http://www.professionalplastics.com/...KnifeFlyer.doc
Scroll down to see some kewl construction techniques.
PlastKut Knife for Cutting Coroplast - PLASTKUT KNIFE - Order Online
It's cost you about $52, but it might be worth it!
aero, aeromods, grille block, scion xb
Building an HPV Fairing trebuchet03 Alternative Transportation 73 01-19-2012 03:50 PM
Where did you buy Coroplast? tjts1 EcoModding Central 28 11-18-2009 02:12 AM
Coroplast undertray question (covering the control arms) Otto Aerodynamics 8 03-30-2009 01:27 PM
Fastening coroplast to the underbody Daox Aerodynamics 2 05-23-2008 03:57 AM
Coroplast question Otto Aerodynamics 14 03-28-2008 12:45 AM
