Old 11-08-2011, 01:59 PM   #1 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 300SD
90 day: 23.23 mpg (US)
I want AlMgB14 bearings and rings.
I was doing some reading and came across something interesting. There is a material that is ideal for bearings. It is AlMgB14 (sometimes called BAM) . It has a hardness that is very close to diamond and is slipperier than teflon.
Aluminium magnesium boride - Wikipedia, the free encyclopedia
it looks like a company called Newtech Ceramics has licensed the patent for the material.
Old 11-09-2011, 11:03 AM   #2 (permalink)
2004 CTD - '04 RAM 2500 SLT
90 day: 21.37 mpg (US)
Have a look also at MICROBLUE RACING
2004.0 7,360-lb DODGE Ram QC/LB 2500 2WD/6-speed Cummins 305/555 ISB. Stock, except LEER bed topper and twin muffler exhaust. 180,000 miles at 4,625-hrs @ 39 mph. 15-cpm solo, 25-cpm towing. (22-mpg avg past 37k)
Fuel Log
Old 02-26-2012, 12:34 AM   #3 (permalink)
dead link?
Old 02-27-2012, 12:03 AM   #4 (permalink)
Toothless - '94 Del Sol Si VTEC
90 day: 30.16 mpg (US)
It's hard, but would it withstand the beating it would take as a rod bearing? Many materials are hard but prone to shattering, and thus are no good for this type of application.
Thanks for the link though, very interesting.
Tank|Trip Milestones
[x] [x] 30mpg - 125% EPA
[x] [x] 33mpg - 138% EPA
[ ] [x] 36mpg - 150% EPA
[ ] [x] 39mpg - 163% EPA
[ ] [ ] 42mpg - 175% EPA
[ ] [ ] 45mpg - 188% EPA
[ ] [ ] 48mpg - 200% EPA
Old 03-23-2012, 03:48 PM   #5 (permalink)
V8 guy
Sub - '84 Suburban C10
Pickups
camaro - '85 Camaro Z28
For harder piston rings you could always go with tool steel rings.
They are pretty hard, I believe you need about a #400 finish on the cylinder bores to break them. Normal bore finish these days is done with #800 grit stones or finer.
1984 chevy suburban, custom made 6.5L high compression diesel.
New engine is in and should be good for 29mpg highway.
1985 chevy camaro mostly stock.
