Old 04-28-2015, 12:18 PM   #31 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by oldtamiyaphile View Post
I'm really impressed Honda were doing it all those years ago. Do you know how the alt is controlled? I wonder if it could be a simple retrofit for 'dumb' units. Based on my experience with 'smart' alts, there's a good 5% gain to be had with no drawbacks.
I think you might need the ECU as well as the Electric Load Detector unit (ELD). Daox is probably correct that it is a bit more complex. There are several wires into the alt... a 4 or 5 pin connector, IIRC. In fact, even with my switch, once I turn the alt on, putting the switch back into off does not shut the alt down, inly cutting the engine will do that. Works well enough.
J
Old 04-28-2015, 09:06 PM   #32 (permalink)
Lafawnda - '01 Honda CBR600 F4i
Big Yeller - '98 Dodge Ram 2500 base
Prius Plug-in - '12 Toyota Prius Plug-in
90 day: 57.64 mpg (US)
Mazda CX-5 - '17 Mazda CX-5 Touring
90 day: 26.68 mpg (US)
My 2006 Acura TSX has a 4-pin control plug to the alternator. It de-energizes when the 4-pin is unplugged, and re-energizes when plugged back in. Output voltage is determined by the ELD (Electric load detector), which is one of the 4 wires going to the alternator.
oldtamiyaphile (04-29-2015)
