Old 09-26-2009, 03:17 PM   #11 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.85 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 28.75 mpg (US)
Originally Posted by dcb View Post
I've heard of 100 low lead, which has an insanely large amount of lead in it still.
...oops, you're correct! It's 100LL, but as of 2008, new 94UL (unleaded = UL) fuel has been available...at some airports.
...insanely amounts?
80/87 (red) = 0.5 ml TEL per gallon.
100LL (blue) = 1.2-2.0 ml TEL per gallon.
100/130 (green) = 3.0-4.0 ml TEL per gallon.
115/145 (purple) = 4.6 ml TEL per gallon.
...planes I flew in used 115/145, called 'grape juice' due to purple coloring.
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SIDI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 09-26-2009, 03:27 PM   #12 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
2 grams per gallon = your typical piper cub spitting out a POUND of lead for every 56 hours of operation. I'll stick with insane
Old 09-26-2009, 03:32 PM   #13 (permalink)
...beats walking...
...I think you're assuming all that "ml"-volume is Pb, which ain't so! At the molecular-level, the percentage of Pb is quite a bit less than 100%, but (admittedly) not insignificant.
TEL = C(8)_H(20)_Pb or ((CH3.CH2)4)Pb
...the Pb is about 64% of the total molecular weight.
Old 09-26-2009, 05:15 PM   #14 (permalink)
chop suey
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Once upon a time I was a lineman at an airport. I tried 100LL in my car. It totally killed the cat, and rather quickly too. Don't try it with anything that has a cat.
Old 09-26-2009, 06:41 PM   #15 (permalink)
dcb
needs more cowbell
dcb's Avatar
Yes, TEL, not pb, per EAA - Avgas Specifications
updating wikipedia...
Old 09-26-2009, 07:30 PM   #16 (permalink)
The Geo - '93 Metro
90 day: 45.16 mpg (US)
You run E85 in a regular engine?
Old 09-26-2009, 08:23 PM   #17 (permalink)
chop suey
Blue - '93 Tempo
F150 - '94 F150 XLT
Me? Yes.
Old 09-26-2009, 09:56 PM   #18 (permalink)
The Geo - '93 Metro
Me? Yes.
How?
Old 09-26-2009, 10:51 PM   #19 (permalink)
There isn't much to get to the bottom of in regards to lower mpg on ethanol. It is there to burn cleaner or "burn a more politicially correct mix" it has less energy (btu's) just as gas has less energy than diesel.
Some states like Minnesota give you a break on the price of E85 to encourage use which results in the miles per dollar coming out close to the same. Flex fuel epa numbers show lower mpg for the same vehicle on E85 vs regular grade gas.
The Impala numbers being a good example
http://www.greenfamilycar.com/index05.htm
Of the "green" fuels B100 has a very high CN number and is in many places also sold with price support. So the folks that have a need for diesel have nothing to lose using it.
Old 09-26-2009, 10:57 PM   #20 (permalink)
chop suey
Blue - '93 Tempo
F150 - '94 F150 XLT
Originally Posted by MadisonMPG View Post
How?
1. Find an E85 pump.
2. Pump it in.
When I blend 50/50 it definitely saves me money cuz fe doesn't drop noticeably and it's about 40 cents/gallon cheaper.
When E85 is the same price as regular I don't mess with it.
free OBD2 software with MPG calc whitewiz Instrumentation 5 02-05-2012 09:40 PM
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 152 10-27-2011 01:28 PM
How to get instant fuel consumption from Megasquirt TELVM Instrumentation 11 08-29-2011 03:47 PM
The Ethanol Scam: Are ethanol advocates giving slanted mpg numbers? Ptero Fossil Fuel Free 15 04-22-2010 10:58 AM
The Ethanol Bubble Pops in Iowa hypermiler01 Fossil Fuel Free 13 04-18-2010 03:19 AM
