Old 10-13-2009, 05:55 PM   #11 (permalink)
micondie's Avatar
moby van - '03 Caravan SE
90 day: 19.74 mpg (US)
Try this site for an explanation of what modifying IAT sensor output does.
Browser Warning
The Following User Says Thank You to micondie For This Useful Post:
Formula413 (10-26-2009)
Old 10-26-2009, 02:52 PM   #12 (permalink)
Browser Warning
Hey thanks alot for the site. Very informative
Honda Car Alarm
Old 10-26-2009, 03:19 PM   #13 (permalink)
micondie's Avatar
Two observations about the IAT sensor mod:
1. The computer can't "learn" that you've altered the IAT signal because it has no baseline to refer to, the temp always varies. It just acepts the temp as OK.
2. With a colder IAT signal the computer does two lthings. It advances the timing and richens the mixture. When it does this it gets feedback from other sensors. The nock sensor will tell it if the timing is too far advanced and the O2 sensor will tell it if the mixture is too rich. In either case the computer will adjust settings for best motor operation. Final result: a correct fuel mixture with advanced timing, the prescription for better MPG
start to play with IAT sensor on Mercedes E250D-Turbo 98' poisas EcoModding Central 5 10-09-2009 11:09 AM
Testing the IAT mod tasdrouille General Efficiency Discussion 6 09-27-2009 04:09 PM
IAT sensor madness Green Machine Off-Topic Tech 10 10-10-2008 08:42 PM
