Old 06-20-2008, 02:52 PM   #1 (permalink)
Tacoma - '06 Tacoma 2wd access-cab base trim
90 day: 32.03 mpg (US)
idea : DIY Fastback top for pick-ups
Hi everybody,
just an idea for DIY fastback top for your pick-up.
a lightweight EMT tubing frame (available at HomeDepot)
then recover with ....
..... Boat shrink wrap !
it's not expensive, it's lightweight, it will resist UV, can be replaced if torn by a little punk and no seams. most are 6 mils think but you can add layers for a tougher top.
I may give it a try on my 2006 toyota Tacoma (2wd access cab 4 cyl). but the 7.5l/100km (32mpg) I have right now is hard to beat. (was 8.2 with the fiberglass fullsize top).
Old 06-20-2008, 03:04 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
Don't really know what boat shrink wrap looks like, but I'd be interested to see it done.
Old 06-20-2008, 03:22 PM   #3 (permalink)
ttoyoda's Avatar
Pluses: smooth and a nice color.
Minuses: shrinking the wrap might pull the sides made of the emt tube pretty hard.
So you might have to brace it a lot.
Old 06-20-2008, 08:38 PM   #4 (permalink)
available in blue, white and clear
Old 06-21-2008, 11:05 AM   #5 (permalink)
penny pincher
kevlar's Avatar
lucky - '92 pickup plain
90 day: 32.08 mpg (US)
Too bad I didn't hear about this before I did mine, I like the already blue part of it ! ...
Every dollar I save, .....I save!
half exposed Lucky http://ecomodder.com/forum/attachmen...1&d=1210727433
how it was done...
http://ecomodder.com/forum/showthrea...html#post25264
as of feb. 09, still holding up great with new owner,
who has since re-geared the rear end and gets nearly 40 MPG!
Old 06-23-2008, 10:48 AM   #6 (permalink)
Veggiedynamics
Extreme CRX-HF - '87 CRX custom areo
90 day: 50.8 mpg (US)
1 minor downfall, it tends to concave, you'll have to make a nice framework to get this right on for areo.. but if its a quick and dirty thing yeah it should help...
However a clear would be pretty cool.. just paint what you want to not be windows.
Old 06-23-2008, 11:17 AM   #7 (permalink)
I was giving this idea, may be it's not the best but it's a cheap option;
another cheap Idea to cleanly block foglight recess : get your local vinyl signs shop cut you a set of sticker a half inch larger than the opening in the bumper. Get a piece of coroplast (the sign guy must have some leftovers), cut it a bit smaller than the fog opening. put the coroplast piece centered on the sticky side of your vinyl cut then put it on your bumper. the coroplast will keep the vinyl patch straight while the patch will deflect the air away and be almost invisible.
Old 06-24-2008, 04:24 AM   #8 (permalink)
Hermit
Aubergine - '94 Ranger 4x4
90 day: 19.14 mpg (US)
Shrink wrap the bumper? One of my wacky plans is to build a cardboard boat hull, then shrink wrap it for waterproofness. Maybe we shoud just use paper mache?
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 140 11-21-2011 09:13 AM
No More Left Turns for UPS EngineeredCivic Hypermiling / EcoDriver's Ed 11 06-12-2008 10:36 AM
Top MPG on website - does % above EPA make more sense? larrydag Forum News & Feedback 16 05-08-2008 03:34 PM
UPS begins using Modec electric truck SVOboy Fossil Fuel Free 7 03-11-2008 09:03 PM
