even ripstop mylar would not be very suitable - in more than one regard.
nylon material used in tents would not hold up long (physically and UV xposure). once again a ripstop variant would be a gross improvement. preferable to that and a lil more expensive dupont *cordura*.
tops would be modern sailcloth very ridgid, ripstop, good uv holdout but also very $$$
ultrathin pvc would be inexpensive and not impossible to weld (seam), flexible
for forming curves. to control unwanted bulging like convertible tops
do on the highway just add some slats or similar stiffeners such as the ones in use for sails. alternatively individual chambers could be used, think motionless waterbed, to add structural integrity and or by varying inflation pressures to help form its general shape. even non UV stabilized PVC is decent in the sun, improved grades should be source-able
if money is no issue, polyurethane - think modern condoms or speedsuits
however durability would have to be determined...
i would be very interested in anything happening along these lines.
project groovy, see my thread in the intro section, will be utilizing
cordura, nylon ribbons for reinforcements and thin wall 1" 1.5" PVC tubing
- quick and dirty ez on ez off.
the fuzz will love it i am sure
