Old 05-02-2017, 03:56 AM   #11 (permalink)
Agreed.
My thought process was: If I can keep the cold air out of the engine, then it will warm up quicker and stay warmer.
I suspect it would be better to have switchable intake system, where I gave it warm intake air until a certain temperature, then switched to cold intake for more power/economy at highway/motorway speeds.
I have re-installed the cold air intake, and cut a small section in my grill block so that fresh air can get to the intake pipework.
Old 05-02-2017, 01:00 PM   #12 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
I use the defrost as a temperature maintenance assistant. When the motor is cold I run the defrost. This duse 2 things .
1 it puts a load on the motor , because more load means more heat is generated per combustion event. Equals more heat being put into the coolent.
2 the heat productionin the freon from the AC compressor is dissipated directly in front of my intercooler and be hind my grill block witch in turn warms the intake air charge ,witch inturn warms the engine at a slightly faster rate . Allowing me to reach efficient operating temperatures faster. The hard part is to remember to switch the controls over to a non AC compressor setting when warmed up but cab heat is still needed. Forgetting tends to offset any potential.
Disclaimer.
I have an old non-computer diesle. So I can not verifie if this actually saves fule . But it duse take less time and miles to reach 100°f coolent. (The temperature my digital temperature gage starts to register. )
One mor tip I forgot. Get a data loger , ScanGauge, tork app with obd2 dongle. Seeing what a particular habitd use to fule consumption is the best way to retool the nut behind the wheel were we typically see the most gain in FE.
Dreem big chisel down to reality
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following User Says Thank You to gumby79 For This Useful Post:
Lin0 (03-27-2024)
Old 05-02-2017, 01:52 PM   #13 (permalink)
Disclaimer.
Thanks!
This car has a heating element in the block that is switched on under high loads. This can help to heat up the coolant but I think its an inefficient way of getting heat into the coolant. I think it is primarily done to give the passengers hot air quicker!
I can also turn on the AC defrost as you say. Not a bad idea that, as you say, it will heat up the engine compartment too (mine is fully blocked nearly).
I have an ultragauge, but its not giving accurate mpg numbers on the diesel. It appears to be unable to detect injector cut off.
