Old 04-15-2009, 09:35 PM   #31 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
MetroMPG -
Those pictures change everything. I vote Frank's wingnut + helical-spring tightener. For it to be "tight", I think you'd still need a torquing tool of some kind. Soooo, the "cost" would be the extra weight of the tool.
It looks to be "easily adjustable" with all those little "slats" (EDIT: I meant splines). Clever.
CarloSW2
American Solar Energy Society
Old 04-15-2009, 09:42 PM   #32 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
MetroMPG -
I wonder if there is some way to fashion the quick release by leaving the nut & splines in place, but cutting the wiper arm itself. Making some kind of sleeve arrangement to slide it on & off the "stub" (and then lock it with a cotter/lynch pin)....
With two of these, one on each side of the arm, maybe could cannibalize hinges & hinge pins for the purpose...
Just thinking out loud.
And yes, I realize more thought is going into this than it's worth.
I disagree. You may find a solution that you use for something else.
How about this Dzus thingy? :
Pegasus - Dzus 1500 Series Sliding Latch and Bushing
The question would be whether the sliding latch would be *designed* to take the lateral stresses of the wiper in action. I think the sleeve would still need to be there, and super-snug.
CarloSW2
Old 04-16-2009, 04:16 PM   #33 (permalink)
The Green Hornet - '96 Escort Wagon LX
90 day: 39.26 mpg (US)
The Red Rocket - '96 Metro Base
90 day: 53.07 mpg (US)
I'll wager the splines won't wear if you keep them lubes with a light grease. Especially if they aren't going on and off that often.
My first thought was a wing nut as well.
Wiper cover test groar Aerodynamics 20 01-10-2012 04:37 PM
Windshield Wiper Cowl / Cover / Blocker Thingy? Sean T. Aerodynamics 42 04-02-2009 02:56 AM
gain from rear windshield wiper deletion cottonfox Aerodynamics 3 03-29-2009 05:21 PM
windshield wiper dashboard assembly--HELP!! 90metro Off-Topic Tech 2 03-27-2009 01:48 PM
One Windshield Wiper Instead of Two Wayneburg EcoModding Central 22 05-08-2008 02:04 AM
