Old 01-28-2009, 11:05 PM   #21 (permalink)
Wannabe greenie
The Clunker (retired) - '90 Accord EX sedan
90 day: 29.49 mpg (US)
Uranus - '04 Ion 2 sedan
90 day: 38.21 mpg (US)
Mountain Goat - '96 Ranger XLT 4x4 SuperCab
90 day: 18 mpg (US)
Zippy - '010 Agility 125
Originally Posted by Christ View Post
I thought lower was better as well... since opening the throttle more increases VE by lessening restriction via the throttle plate, which reduces vacuum... I was under the impression that regardless of gear or engine speed, less vacuum would create better efficiency.
On my car, the more throttle, the lower the vacuum. When I'm climbing the hill, if I give it slightly less gas, the vacuum goes from 3 to 6. Does that mean I'm using more gas by using less throttle?
Old 01-28-2009, 11:14 PM   #22 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
I see now... I didn't realize you were talking about going up hills and such.. so is higher vacuum generally better? How can you tell when to use higher or lower vacuum for a given situation? Sorry - I'm doing my taxes right now too.
Old 01-28-2009, 11:18 PM   #23 (permalink)
Wannabe greenie
90 day: 18 mpg (US)
I go for the highest gear first, and the highest vacuum second. The vacuum gauge helps me because often I can ever-so-slightly let up on the throttle and still maintain the same speed. It allows me to drive without taking my shoes off. :-)
Old 01-28-2009, 11:21 PM   #24 (permalink)
Steve - '92 Festiva
So keep it in 5th whenever possible, and keep the vacuum as high as the engine will allow - right?
How does this methodology apply to forced induction? Am I still trying to keep a high vacuum number? (Or as low boost as possible, given certain situations). If you don't know, it's no biggie, I was just wondering.
Old 05-25-2009, 01:39 AM   #25 (permalink)
I know this is an old post, but I'm catching up on the forum and wanted to weigh in.
Vacuum gauges are a great and simple item to add to your ecomodding. But you can't get too wrapped around numbers. 18-20 are good for idle, 3-5 for acceleration, 25+ for decel. Book values.
What it really provides is INSTANT feedback about where your throttle is. If you're accelerating from a stoplight at 10 in/Hg, ease your foot a bit at you'll get 12" and better economy with no noticeable speed differential. None of the electronic doodads give you that feedback that quick. A tach tells you how fast the crankshaft is turning, but has nothing to do with fuel consumption.
But the best part of a vac gauge, is the diagnostics. Is it low at idle (restricted exhaust?), have a regular drop (burnt valve?), wandering needle (carb probs?)
They are relatively cheap and easy to install. Initially ignore the numbers and just see where your car fits. Once you understand your engine's personality you can truly tweak it for max mpg
Old 07-20-2009, 04:25 PM   #26 (permalink)
Speedboy turned MPGman
kstruve's Avatar
Platinum Bullet - '04 Impreza WRX
90 day: 27.53 mpg (US)
I had wondered about how vacuum gauges help with efficiency myself. I just realized that my car (Subaru WRX) already has one installed! It's my turbo boost gauge - duh. I never really paid much attention to its behavior below 0 until recently. My gauge's units is in MPa (megapascals) instead of inches of mercury, but I found an online converter and found that 15 inHG is about .05 MPa on my gauge. So now I should keep it well under 0 from now on.
www.kurtstruve.com
Old 07-21-2009, 02:09 PM   #27 (permalink)
The Atomic Ass's Avatar
2-Wheeled Mule - '06 Burgman 400
90 day: 84.89 mpg (US)
Max - '01 S-10 LS
90 day: 24.7 mpg (US)
Twin Powa - '05 Ninja 250
90 day: 79.09 mpg (US)
Ransom - '01 Bravada
90 day: 16.39 mpg (US)
Send a message via Skype™ to The Atomic Ass
Originally Posted by solarguy View Post
Cough...I drive a diesel...cough...neither one works...cough.
Seriously, neither option works for me. MPGuino is unsuitable for VW diesel , right?
Other options? I got the basic '04 Jetta TDI PD, without the fancy schmancy gauge cluster, so no readout of FE of any kind. I don't feel like doing the junkyard thing to replace the cluster.
I know it's a late reply, but if a diesel engine has electric injectors as opposed to mechanical, wouldn't it still be a candidate for an MPGuino?
ASE certified day-dream engineer
I'm making beautiful music's now, hear it and like me on Facebook!
Old 07-21-2009, 05:21 PM   #28 (permalink)
My Goal: 35 MPG All City
RandomFact314's Avatar
The Neon - '00 Neon
90 day: 25.38 mpg (US)
G/F's Car - Kyan - '01 Rio
90 day: 23.94 mpg (US)
The Accord - '97 Accord LX
90 day: 22.41 mpg (US)
Lizzy (all city) - '88 CRX Si
House of Tudor
90 day: 31.92 mpg (US)
Yeah I am really thinking about getting a vacuum gauge but I still am not sure where to plug up the pipe?
Old 07-21-2009, 09:19 PM   #29 (permalink)
Max - '01 S-10 LS
Need some more shots of your engine a little further right. Easiest place is going to be on the throttle body, then you can take basically any small rubber line and it will be vacuum.
Old 07-21-2009, 10:38 PM   #30 (permalink)
The Neon - '00 Neon
House of Tudor
Its hard with this 127 limit, Besides, I thought it was suppose to come from the intake box? and that is the very far right of my engine bay...
10-minute Accord vacuum gauge "install" Clev DIY / How-to 7 09-10-2010 03:53 AM
Econometer/Vacuum Gauge Installation Guide Johnny Mullet Instrumentation 76 07-29-2010 08:52 PM
Used Vacuum Gauge for hypermiling holypaulie For Sale 5 11-26-2008 12:29 PM
no vacuum for vacuum gauge? modmonster Instrumentation 2 11-07-2008 07:40 PM
Vacuum gauge problems :( DifferentPointofView Instrumentation 3 05-14-2008 11:04 PM
