IGBT driver board
1 Attachment(s)
Finally I have the parts that do go along the IGBT driver board for the Paul & Sabrina revolt controller board. Based on Powerex electrical design and Paul's PCB art layout.
I will be supplying the bare PCB and the PC board with almost all parts, excluding the VLA500-01 and the 2 gate power resistors. Gate resistors (R3 and R7) depend on the preferred IGBT to be use, values will be in the range of 1.5 to 12 Ohms, 2 Watts dissipation. Parts will be supplied populated on the board but unsolder to minimize parts bagging, labeling and placement mistake. The parts kit: 6 Zenner diodes 2 Ultra fast recovery diodes 5 resistors 2 Optoisolators 5 electrolytic cap. 2 right angle connector headers 1 straight connector header 3 header connector sockets 12 gold crimp/solder pins All parts distribution will be handled by USPS flat rate mailers in continental USA. International orders are welcome, inquire whiting. Payment will be through PAYPAL. |
I'll take 2! What's the availability on the vla modules?
While I am planning to go AC, I wanted to say way to go !
Thanks for pulling the pieces together for those who don't know their way around the suppliers. |
TEST it, not. We haven't purchase the VLA500-01 yet. We need at least a 5 pieces minimum order; I'm good for 2 at least. I will send you the Paypal contact info after I get the USPS charges, sidetracked by the snow by hell, if you know what I meant. |
Not to bad. |
Ok well i'll need two vla modules. If we can't get 5 people i'll take up the slack.
ok, i will take 5, just send me your payment info, boards will come populated, minus gate resistors and vla, ok by me
I'm in PM conversation with mrbigh now; trying not to sound like a dunce in front of everyone. I may be in for one board kit and 2x VLA's as well.
Where are the VLA's coming from? Best I found was $37.78 from Richardson: VLA500-01 Powerex HVIC - Richardson Electronics Ltd |
yep, i saw them there, not many availible though, only 36 in stock
I will be able to place the order for the VLAs and distribute them with the PC boards. |
