Old 07-29-2011, 02:49 PM   #21 (permalink)
101% win
roflwaffle's Avatar
Camryaro - '92 Camry LE V6
90 day: 31.12 mpg (US)
Toy - '82 Pickup
90 day: 24.44 mpg (US)
Originally Posted by Old Tele man View Post
...come up with some way to interrogate, integrate, and display a realtime Brake Specific Fuel Consumption (BSFC) graph for the engine.
To be fair that would be a DSFC (Driveline), and it would be kind of a pain. Not all OBDII vehicles have load, airflow, and trans lockup values IIRC, and the user would still need to input several tanks to calibrate it due abrupt changes in operating conditions due to non-stoich, trans unlocking, or whatever, although some of that could be inferred by the change in vehicle speed wrt engine speed or idle speed during startup.
Old 07-29-2011, 02:49 PM   #22 (permalink)
Location: Live in Tucson AZ, work and car now in Detroit
Protege - '97 Protege DX
90 day: 42.23 mpg (US)
Let's think about the GPS capabilities.
1) How accurate is calculated speed from GPS? Can I calibrate my SG to GPS. Right now my Speedo and my SG are different by 1.5-2%. I don't know which is more accurate.
2) I don't need all the street/turn stuff. I need to know how far I traveled since I hit the button. What was my change in "altitude" since start. I'm I heading uphill right now or downhill and by what percentage. I want to save GPS start and end points so I can collect A-B-A testing data automatically.
Old 07-29-2011, 05:49 PM   #23 (permalink)
Vekke's Avatar
Siitin - '98 Cordoba Vario
90 day: 58.56 mpg (US)
Starppa - '96 Starlet
90 day: 35.06 mpg (US)
Aeroscania - '97 P94D 260
90 day: 9.35 mpg (US)
VW Lupo 3L --> 2L - '00 Lupo 3L
Diesel
90 day: 63.49 mpg (US)
Here is some of the functions what my econavigator should have. First of all the ultimate navigator should have all the possible functions what are on the 100 driving tips list. Driver then could decide what he is willing to use.
- Navigator should calculate the "gliding properties of the car" CD and CRR and other forces, like already mentioned. Can be done with basic coast down test.
- When you have extra load you should be able to tell the computer that.
- Also topografic map is a must where it can calculate height differences and effect to glides. With those you can calculate the points where to put the car in neutral according to parameters that driver had feed inside the computer. Like I want to come to juctions at 15 MPH speed. Or I am willing to slow down my speed in hills 10 MPH etc. Navigator can also use some other data to calculate the descents. These are the fuctions which the driver should be able to feed/tell.
- Navigator should tell the driver when are best point to start P&G. So avoid Push on hills etc.
- Could tell also that what speed you should enter the top of hill if you dont want to overspeed on the downhill. Also driver can tell what the driver is willing to speed.
- navigator should tell how fast driver should go to reach the destination on time
- Basic BSFc maps are prettyu similar if you feed engine displacement, fuel type, turbo or non turbo, max torgue and power points. From there the computer can estimate the fuel map.
- Places of speed signs so you can glide before you can even see them and of course the computer calculates optimal gliding points.
- tell optimal acceleration and decelaration methods.
Where would you get that topografic map?
If you can do those then I can tell even more extreme stuff that is needed to make it best navigator app. If that navi has everything and they save easily over 20% on fuel costs people are ready to pay big $ for it. Most expensive navigators in finland cost well over 400€ and simple stuff like this over 1000€. Mobileye | Fleet Safety. Also that kind of thing is needed in some funtions I have planned.
Why people buy phones and then navigators when that can be one unit and you save money and time.
www.tuneko.com
Less drag = Less fuel
Old 07-30-2011, 02:28 AM   #24 (permalink)
Cd
Ultimate Fail
Cd's Avatar
My number one request : make an ANDROID app.
I don't have an eye phone
Also, my car is a 1993 car. It sure would we nice to have something us po'folks with the junky old cars could use.
"You don't fail until you give up. You learn, and move on." - Christ
" Hypermiling is not going slow, it's driving with more intelligence." - UFO
Old 07-30-2011, 11:03 AM   #25 (permalink)
Wiki Mod
Weather Spotter's Avatar
AeroTrix - '06 Matrix base
90 day: 42.69 mpg (US)
I would also second the Android app idea
