Old 11-12-2013, 12:23 PM   #1 (permalink)
Misanthropologist
captainslug's Avatar
BORK! - '89 Volvo 240 DL Wagon
90 day: 21.27 mpg (US)
The "Impaler" - Go-Kart Dual Sport
So I learned a hell of a lot working on my electric motorcycle project, but it eventually hit a dead end in terms of budget and time available.
http://ecomodder.com/forum/showthrea...ycle-6481.html
In March of last year I revisited the goals of that project and ended up deciding that what I basically wanted was a Go-Kart, but one that only had 2 wheels.
After 2 months of planning, machining, and welding this is what I had.
With some refinements over the summer I got to this point.
A year and a bunch of small changes later it now looks like this.
  • Top Speed: 45mph
  • Wet Weight: 180lb
  • The fender\headlight is made out of 22ga stainless steel that I cut and welded together.
  • The frame is from an X-Motos XB-31 (Chinestraulian Honda knockoff)
  • The motor is a 196cc LiFan clone of the Honda GX200 with electric start. I haven't removed the governor on it yet.
  • Primary reduction is a TAV2 Torq-a-verter CVT
  • The electrical system was added from scratch.
  • The air cleaner had to be moved and reoriented so I made a hose adapter for the carb.
  • The aluminum motor mount was made from scratch and doubles as an enclosure for the electrical system which is all DIN-rail mount components.
  • The forward motor mount is from scratch
  • The rear sprocket was milled out to match the rear hub bolt pattern and to reduce weight. It's the only custom part on the bike that I didn't make myself
  • The fan cover which replaced the old recoil start cover was 3D printed.
  • The push-button switch shown on the bracket above the fan housing that holds the air cleaner is the hidden push-button start.
  • Aluminum clip-on handlebars are from scratch. The core of them is a 5-inch long 1/2-13 bolt.
  • Speedometer is a bike computer
  • Headlight is a Vision-X Solstice 800 lumen LED spotlight
The Following 2 Users Say Thank You to captainslug For This Useful Post:
euromodder (11-12-2013), UltArc (11-26-2013)
Old 11-12-2013, 02:20 PM   #2 (permalink)
la_voiture_de_courses - '03 Renault Megane Estate
OldContinents
90 day: 44.34 mpg (US)
xiao lan - '01 Audi A2
90 day: 38.88 mpg (US)
Brit iron - '92 Mini Mini
90 day: 45.5 mpg (US)
Prius - '09 Toyota PRIUS Lounge
90 day: 47.37 mpg (US)
Beemer - '06 BMW F800 ST
90 day: 53.06 mpg (US)
You wouldn't want to convert it to electric, would you ?
Old 11-12-2013, 02:27 PM   #3 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Looks a bit mean, but I like it
Old 11-13-2013, 09:20 AM   #4 (permalink)
Nice work!
Old 11-13-2013, 03:03 PM   #5 (permalink)
Nice.
Old 11-26-2013, 03:45 PM   #6 (permalink)
Misanthropologist
New exhaust is finished. I bought an 11-inch clearance mini bike header from OMB Warehouse, cut it short, welded a 3/4 NPT half coupler onto it, then made and welded on a tab so I can secure it to the frame.
The muffler is a cheap stock Briggs & Stratton.
http://www.captainslug.com/temp/vlad_046.jpg
