Old 07-02-2008, 06:56 PM   #1 (permalink)
pcp
pcp's Avatar
improving my van
Hello everyone I own a Hyundai H1 van with a 2.5 turbo diesel motor, it will do 600km on a tank . It has a 65 liter tank and when I refill it it takes 54 literes, I don't let it run to long with the fuel light on. Any suggestions at improving the FE.
Old 07-02-2008, 08:59 PM   #2 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Christine - '98 Metro Base
90 day: 62.59 mpg (US)
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
If you feel comfortable to do this...................
Remove excess weight like the spare and all the junk in the trunk
Inflate the tires to max air pressure marked on tire
Remove roof rack if equipped
Old 07-03-2008, 02:29 PM   #3 (permalink)
Van
Go to GOOGLE IMAGES and type in a search for NASA images van Boat-tail and see if that gets you photos.Such a tail ( only 18-inches long ) added 4-mpg to my van.Also there is a link to it at maxmpg LINKS.
Old 07-04-2008, 07:40 PM   #4 (permalink)
pcp
pcp's Avatar
I have inflated the tires to 65 psi the max on the tires, and I neutral coast as much as possible.
Old 10-25-2008, 05:27 PM   #5 (permalink)
Diesels aren't often discussed here, but I would think they would respond well to eliminating intake restrictions (adding a cold air intake, etc). The trade-off here will be at least noise. The aerodynamic mods discussed elsewhere and by aerohead will help most on the highway, and Mullet's weight reduction suggestions will help especially in the city. Keep the speed down, keep up on maintenance, maybe a low-viscosity synthetic oil. Not much you can do for a diesel.
1987 Chevy G20 high-top van - 305, TBI, 11MPG on its only trip
Old 10-25-2008, 10:26 PM   #6 (permalink)
Weight Reduction
ankit's Avatar
4x4 - '06 Altima 2.5 Special Edition
90 day: 29.04 mpg (US)
Mom's Van - '99 Voyager SE
90 day: 25.62 mpg (US)
Send a message via AIM to ankit
Judging from your avatar, your van has an NONFUNCTIONAL hood scoop. That is not the best for fuel economy either. Also try to find out if your car has an Fuel Cut Off. If it does, then you might not be saving fuel by dropping it into neutral. That's how it is for me.
Most of my trips are made in rush hour traffic to and from school.
Live Simply So Others Can Simply Live
-Ed Begley Jr.
Old 10-26-2008, 07:30 PM   #7 (permalink)
Greta - '00 Jetta TDI
90 day: 59.96 mpg (US)
Send a message via Skype™ to ChrstphrR
Being that you have a diesel, more of the modern diesel engines will suspending fueling when in gear and off-throttle, which would be more fuel efficient than coasting in neutral.
Offhand, I don't know if Hyundai's diesels do. VW's TDI engines do, that much I do know.
Without someone authoratatively saying so, or without tools/gauges to check your fuel use, the only way you'd be able to tell is... try and see, and check after the tank needs refilling.
Current mod: Skidplate/Undertray for my MkIV Jetta. Next mod: CAD drawing for skidplate so other Jetta/Golf drivers can make one too!
5th generation civic hatchback - improving aerodynamics AndrewJ Aerodynamics 383 05-15-2012 08:40 PM
Report: Improving the Aero Characteristics of a Dodge Ram Pickup Truck MetroMPG Aerodynamics 34 11-12-2011 11:45 AM
95 Chevy Van - remove lower valance? HeavyChevy Aerodynamics 4 06-25-2008 05:37 PM
Improving and tracking. brucey Introductions 10 04-03-2008 07:52 AM
Several tips on improving MPG ( article ) Cd Aerodynamics 1 03-28-2008 08:04 PM
