Old 12-24-2014, 03:16 AM   #1 (permalink)
Boltar - '19 Chevy Bolt LT
Inconsistant MPG Data ('08 Prius display vs. Ultragauge)
Here is what is happening. The internal Prius MPG gauge will gave about 43.5 MPG last tank. My Ultraguage said that I was getting about the same 43.2. Yet when I filled up my calculations showed I only got 40.8 MPG.
The Prius also alerts me that my gas is low when the ultraguage still shows I have 3 gallons of gas left.
Has anyone experienced these issues before?
Old 12-24-2014, 08:24 AM   #2 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
No real issues here. 43.5 is only 1.06% higher than 40.8. There are so many variables involved that having the gauges and the pump only 1% off from each other is pretty damn smooth.
The factory fill warning would tend to be conservative- it's not there so you can decide how far to take the tank, it's to give average people time to work a gas stop into their schedule.
Transmission type Efficiency
Old 12-24-2014, 09:06 AM   #3 (permalink)
Not bad for a machine
dirtydave's Avatar
Maechunbu - Retired - '00 Kia Sephia 1.8I4 16VDOHC
Last 3: 45.28 mpg (US)
Slasher - '96 Chevy Corsica 2.2L 3speedauto
Duct Tape Aero Crew
Team Chevy
90 day: 34.76 mpg (US)
^^^^ yeah 3 / 10 sounds like a good time to refuel.!!
And everything looks very close to each other soo uhh its fine..?
Do you use the same gas pump every time? Remember this is a passenger car it doesn't really matter if the gauges aren't 100%Close enough is good enough for me.
Maybe increase the engine size in UG to report a lower MPG number so you are suprized every time?
Old 12-24-2014, 07:29 PM   #4 (permalink)
Thanks for all the info everyone. Just made a trip up the grape vine and my gauges were showing high 40s but when I manualy calculated I got 52. It's funny when you actually calculate the difference percentage wise it's a very small difference when 40 to 43 feels like a big difference.
Merry Christmas Everyone!
Old 12-24-2014, 10:39 PM   #5 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
You mean 6% off. That's on the high side of the accepted margin of error for a throttled engine. I'd recalibrate the UG and ignore what the OE instruments say.
Old 12-24-2014, 11:21 PM   #6 (permalink)
I thought that seemed high. I will definetly reset my ultra gauge and make sure all the custom settings are correct. I know I have the engine displacement set correctly. Not really sure what else I need to do.
Old 12-26-2014, 09:18 AM   #7 (permalink)
Rat Racer
I mean 1%. Call it 2% if you want.
40.8 mpg = 5.765 l/100km
43.5 mpg = 5.407 l/100km
40.8 x 1.066 = 43.49
Using "normal" numbers, the distances reported per gallon are close enough to 1.06% off to use that as a number.
5.407 x 1.066 = 5.763
Translating into metric and working backwards, the amount of gas used to travel 100 km are also close enough to 1.06% apart.
Those numbers are close enough that I'd call the UltraGauge calibrated and move on with my life.
Old 12-26-2014, 09:34 AM   #8 (permalink)
Team Turbocharged!
Pickups
Then you sir have failed maths class
A factor of 1.06 is not the same as 1.06%, it's actually 6%.
Old 12-26-2014, 09:46 AM   #9 (permalink)
wdb
lurker's apprentice
PlainJane - '12 Toyota Tacoma Base 4WD Access Cab
90 day: 20.98 mpg (US)
40.8 is 2.4 MPG or 6% lower than 43.2. That said, if calibrating a UG is anywhere near as hit/miss as calibrating a SG, I'd try tweaking it once or twice at most and then settle into using it as a relative measure.
We once went 50 miles in my wife's CRV with the low fuel warning light on. Drove her crazy.
The Following User Says Thank You to wdb For This Useful Post:
broski499 (12-30-2014)
Old 12-26-2014, 09:48 AM   #10 (permalink)
Rat Racer
Thank you!!!
That's why I posted, because tapping away on my phone made it look fine to me and I wanted someone else to look at what I was doing to confirm or deny the accuracy. Maybe now that Christmas is gone the kids, traffic and all sorts of extra events will calm down or go away and I can start to see straight again.
What really matters here is which gauge agrees more with the pump.
