Old 12-01-2009, 04:33 AM   #1 (permalink)
Increasing Accelerator Pedal Resistance
Is this a plausible way to avoid accelerating more rapidly than intended?
Of course there is the decreased acceleration ability = decreased safety argument. But when you consider that a 1999 Hummer does 0-60 in 15.5 seconds, it seems like all one would have to do is preserve the ability to accelerate faster than this.
I was thinking of something along the lines of a wedge of rubber/silicone/foam etc. under the pedal.
So what do you think? Is mechanically increasing accelerator pedal resistance a reasonable idea?
Old 12-01-2009, 06:59 AM   #2 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
I'd say get a scangauge and learn how to drive more efficiently is a much better option.
Old 12-01-2009, 07:28 AM   #3 (permalink)
EcoModding Alien Observer
suspectnumber961's Avatar
highcountryexplorer - '86 720 KC 4x4 ST with fiberglass cap
90 day: 20.51 mpg (US)
Elroy - '03 Focus ZX3 w/Zetec DOHC engine
90 day: 33.43 mpg (US)
What works real well is an additional spring on the accelerator linkage...set up so that you can feel extra resistance near the throttle position that you typically need to hold speed at say 55 mph. Acts much like using a vac gauge..except that you don't need to watch it. You can easily overide the spring when needed. Just has to be done right so there is no chance of your accel pedal sticking.
A block of soft rubber might work also.
Advantages? It works and doesn't cost a lot. Cost effective.
You naturally develop the habit of driving for mpg.
Carry on humans...we are extremely proud of you. ..................
Warning: There are unicorns about...DO NOT throw anything unusual into their enclosure...they might stomp it and also you if you are not quick enough.
Old 12-01-2009, 09:12 AM   #4 (permalink)
5.4L Econo Box
Jim Allen's Avatar
Plugger - '05 F-150HD 4x4 XL
This is a good point.
I find that cars/trucks with electronic throttles are hyper-sensative and the pedal slopes programmed in are designed to give more throttle response with less pedal movement, making them very touchy. I'm working on reprogramming that in my rig, but in the interim, have been thinking about some way to increase tension on the pedal.
With my F-150, if you take a deep breath, you can effect the throttle. Sneeze and you're doing 90! Seriously, most times I can manage good throttle control, you have to work pretty hard at it. Too hard, IMHO.
Jim Allen
The Frugal Four Wheeler and Farmer
My ultimate goal is not necessarily the highest mpg but to make my trucks more efficient configured as I need them.
Old Reliable '86 Ford F-250HD 4x4, 6.9L diesel
Red '00 Honda Accord Coupe, 3.0L V6, automatic
The Plugger '05 Ford F-150HD 4x4, Regular Cab, 8-ft bed, 8,200# GVW, 5.4L V8, automatic, 4.10:1 ratios, 285/70R-17D tires
Old 12-01-2009, 11:28 AM   #5 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
the block probably belongs under the brake pedal
Old 12-01-2009, 11:36 AM   #6 (permalink)
pgfpro's Avatar
Check this thread out.
Dynamic Map Sensing Throttle Feedback
Online tool: shows aerodynamic drag, rolling resistance, power required & est. MPG MetroMPG Aerodynamics 66 05-22-2012 06:52 PM
Calculating Rolling Resistance SVOboy EcoModding Central 2 02-15-2012 08:43 PM
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 140 11-21-2011 09:13 AM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 68 02-21-2010 08:45 PM
New tires for the truck--rolling resistance and mpg savings 07b2300 EcoModding Central 14 07-01-2008 12:29 PM
