Old 11-25-2010, 09:39 PM   #1 (permalink)
Increasing F-350 efficiency
I'm driving my Dad's 2002 F350, (quad cab, duallie, 4wd, automatic). Till my Mom gets out of her wheelchair he's traded me for my minivan.
The truck gets 9mpg according to the onboard computer, 11ish on the highway. With fuel economy that low even a small 2-3% increase would pay off pretty fast.
Do the typical air intake, exhaust, programmer mods actually improve fuel economy if you keep your foot out of it? Wondering what works and what doesn't?
While I realize this is hardly the typical ecomodder vehicle, I'm hoping someone here has been down this road. Over on the diesel truck forums guys are primarily interested in maximum power, regardless of fuel economy.
Old 11-25-2010, 10:26 PM   #2 (permalink)
comptiger5000's Avatar
The Beast - '98 Grand Cherokee (ZJ) 5.9 Limited
90 day: 14.58 mpg (US)
Is it gas or diesel? If it's diesel, it should be getting significantly better mpg than that.
Regardless, improvements in driving technique are going to yield the biggest gains short of significant modifications, and are the easiest things to do.
Call me crazy, but I actually try for mpg with this Jeep:
Typical driving: Back in Rochester for school, driving is 60 - 70% city
Old 11-26-2010, 10:49 AM   #3 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
Check the tires for uneven wear as a first step in seeing if it has proper alignment as it's common with work trucks to torque the frame while towing or using a snow plow.
It's also most likely about time for a fluid change, synthetics all around, check into getting a shop manual for it and read their list of mantainace suggestions.
Thing is, your truck is in the class of commercial duty or heavy duty trucks and does not have any EPA numbers because of that, there for it's not regulated and the mileage you are getting is most likely close to what it was designed to get.
Old 11-26-2010, 10:49 AM   #4 (permalink)
Eco-ventor
Princess - '92 MX-3 GS
House of Tudor
90 day: 33.52 mpg (US)
Send a message via MSN to jakobnev
Lazy truckbed aeromod.
Maybe you could try something like this. The idea is to allow smoother flow in the trapped vortex, and still be discrete and simple and practical and all that.
The blue lines in the image are just bent plastic rectangles.
Old 11-26-2010, 11:04 AM   #5 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Or he could try what's been proven- a 1/2 tonneau or a full one.
Or better yet park the dang thing and get something realistic to drive.
Old 11-26-2010, 12:42 PM   #6 (permalink)
MPG>HP
Little Blue - '09 Focus SE
Team Ford
90 day: 34.41 mpg (US)
If it's a diesel a hotter thermostat should help.
A larger less restrictive exhaust won't help MPG.
Best Tank:36.915MPG|422.6Miles
Longest Tank:35.2MPG|435.8Miles
Best Trip:45.9MPG|5.9Miles
Old 11-26-2010, 01:09 PM   #7 (permalink)
Eco-ventor
House of Tudor
True, but that's not nearly as interesting
(Do full tonneaus even work for mileage? I remember reading that they don't)
Old 11-26-2010, 01:57 PM   #8 (permalink)
Blue - '93 Tempo
F150 - '94 F150 XLT
Sounds like you need to study up on it then.
Old 11-26-2010, 02:02 PM   #9 (permalink)
Northern most ecomodder
reddxhatch - '95 Civic DX
90 day: 46.04 mpg (US)
with the aerodynamics of a barn and how heavy that thing is driver modification will yield some pretty big improvements.
Slowing down such that you don't have to use the brakes much except to stop where required will be huge.
Reducing your aerodynamic loads by reducing velocity will help a lot as well. can you go 55 in stead of 65?
depending on how long your going to be driving the f350 a cheep econ-o-box in the 500 dollar range may save some cash then sell the thing after you get your van back. please don't misunderstand as I realize a full size and very capable truck has it's place.
The performance mods, while they claim to increase mileage really don't do much, it requires a certain amount of energy to accelerate a mass and overcome the drag. performance mods can't change or reduce those energy requirements. They really only help at high power settings and that is not where economy is going to be made.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
Old 11-26-2010, 06:10 PM   #10 (permalink)
I are aerodynamic kitteh!
t vago's Avatar
2000 Fiat Dakota Quad Cab - '00 Dakota Quad Cab SLT
90 day: 18.33 mpg (US)
Dakota A-B-A HAI - '00 Dakota Quad Cab SLT
90 day: 19.38 mpg (US)
Make a tonneau cover, a partial grille block, and a front air dam that shields your undercarriage. Raise your tire pressure to 5 psig above what Ford recommends, or to the rated pressure listed on the sidewall of your tires (whichever is lower).
2000 Dodge Dakota Quad Cab
2002 Chrysler Sebring Convertible GTC with transplanted 3.5L LH engine
diesel, powerstroke
Announcing a complete solution to mapping engine efficiency kubark42 Instrumentation 80 01-14-2011 09:36 PM
The Easy Leg: Vehicle Efficiency natefish Off-Topic Tech 17 05-19-2010 04:52 PM
Import Tuner Magazine: mods an Integra for speed, handling and efficiency MetroMPG EcoModding Central 15 03-18-2010 02:14 AM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 68 02-21-2010 08:45 PM
Getting more efficiency out of a ZX2. Small list of mods and driving tips for it. koihoshi EcoModding Central 9 07-20-2008 04:26 AM
