Old 12-09-2009, 11:55 AM   #11 (permalink)
Gas Passer
Burnt's Avatar
Burnt's Cobalt - '09 Cobalt LT XFE
Team Chevy
90 day: 38.66 mpg (US)
Originally Posted by jamesqf View Post
Could you elaborate on what this readout is? Is it something like a ScanGauge, giving you an actual temperature value? If so, it's probably pretty accurate. Temperature gauges, OTOH, I've never found to be more than ballpark accurate, if that.
The cobalt has a LCD readout that you can cycle through to see different things about the car - one of them is the coolant temperature value, in fahrenheit ; I'm assuming thats why there is no temp gauge on the car
cfg83 - I'll try to idle it to see when the fan kicks in, thanks for the info
guitarguy - thanks for the pointers about the grill block - I looked at all the pics of grill blocks here on the site; i'm going to try to make one that attaches to the bumper, right behind my grill....yeah I'm definitely not attaching anything to the radiator, haha
Fuel Economy related papers tasdrouille General Efficiency Discussion 33 03-06-2012 12:22 PM
Some graphs of temperature vs. MPG McTimson EcoModding Central 22 03-23-2009 09:06 AM
Coasting experiment: engine on VS engine off on a fixed route = 12.9% gain MetroMPG Hypermiling / EcoDriver's Ed 6 02-22-2008 08:38 AM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
