Originally Posted by Christ
Do you have a holesaw that will just barely fit over the camera? That'll be the one you want to use, and then seal the camera into the mount with hot glue or silicone caulk.
Camera came with core drill included. I'm not quite too sure if I can adjust the camera using the adjustment rings on a curving surface, but hey, I can always try, can't I?
